I acdidentally recorder over a very import ant video, is there a way to recover it?
SOURCE: samsung SC-DC173(U)
I've been trying to find out the same information. We went to disney this year lost 3 full dvd's worth. Called samsung all they told me was to use memorex mini-dvd's. Thanks alot ):
Anyways hopes this helps a little.
SOURCE: Broken video management file/ recording failure
Although the instructions don’t make it clear, it seems to be important that the camera is turned off before you connect or disconnect the USB cable. The instructions do mention that you should not delete or rename files on the camera except in the EXT_MOV folder. The camera’s firmware is apparently quite fragile about file names and the presence of the extra hidden folders that both the Windows and Macintosh operating systems create when you delete something.
SOURCE: movie recording disabled
I have the same problem. If you have taken the disk out of the re-corder, then you can no longer finalize the disk...and you will potentially lose the data on the disk. Their only solution was to take it to a professional media service and see if they could recover it...what a joke...at no point in the manual does it indicate that you cannot remove your disk or face the potential of losing your recording...I lost the recordings of the birth of my son...I will never forgive that...
SOURCE: Is there any way to record a video onto the sd card instead of tape?
You can't. SD card is only to take images in this camera.
SOURCE: same problem "movie recording disabled"
Scott,
Since this is a new camera, nothing was changed as far as the disc, it should work, has it been switched to "still" for photos, that's the message that comes up when you change it. You shouldn't have to finalize the disc before you shut off the camera, try starting it with another disc then shut it off replace it with your baptism disc and try to preview the video, if it shows you should be able to aad to it or then finalize it.
randy320sgi
