Question about RCA HD52W59 HDTV Projection Television
Big Screen problem
Our problem is curved picture and doubled picture. According to the this website it's the convergence board. I purchased the one for this TV and put the new one in tonight. Nothing changed same issues so could you please help us. What else could my problem be???
  • 1 more comment
  • rjones4 Nov 08, 2008
    It's a big board with 12 alum tabs sticking up on it and it's located in the back of the TV on the right hand side. This is a HD52W59 and when you go to the Customer Menu we do not have the option of convergence. I will now try to check the fl231 deal. I will let you know what I discover, I really hope you are able to help me with this issue. I will be getting back with you.
    Thanks Rhonda
  • rjones4 Nov 16, 2008
    Way to go Willtab you fixed our picture problem it was the fuse. I am so grateful for that during all this process of messing the the picture we have now lost sound. Any suggestions.
    Great job you fixed my problem but for some reason now I have lost all sound. If you have any advise that would be great. Otherwise thank you for all your help help with the other problem.
    Genius:
  • 1,030 Answers
What did you put in. convergence amp or convergence power. this is a rca hd52w59? i always ask the question in customer menu under setup can you see the option of convergence. if not this is the fl231 fuse problem. consult the article fl231 under tips and tricks section of my profile. the curved picture is an indication complete loss of convergence power. there is a board that does provide convergece power. The convergence on this set is controled by three diffrent boards. power,amp and the small signal board. the small signal board is the most expensive and most complicated to replace ussally a tech has to replace that.
Posted on Nov 08, 2008
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
My mitsubishi 55" has double
Tv have a problems known as a convergence problems,it dead.The tv convergence board must be replacing parts to solved the tv picture convergence problems.U have all the tools like a soldering iron,desoldering pump or a roll desoldering braid and a roll of solders?Can u also do basic soldering works?Yes,to all these answers.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to do the repair ur self.Or the shop,will cost u like $300-350 for parts and labors.
Jan 17, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The red coler has started to curve about a third of the way down the screen. everything on the the screen is distorted and doubled in red
if your picture looks 3d it is convergence problem.
This is a do it yourself repair if you have some skill.
I will tell you what you need and have start to finish, step by step instructions for this repair along with photos, and source for parts needed(parts cost will be under 30 dollars).
reply here if I can help.
SD TECH
Oct 24, 2010 | Mitsubishi WS-55807 TV
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Curved screen and double letters
i see this alot and rca shold issue a bulliteen. so i wrote advice on this. see fl231 problem under tips and tricks under my profile. this is a simple easy inexpensive repair. if this dont help let me know.
Sep 19, 2008 | RCA HD52W59 HDTV Projection Television
The convergence circuit has a problem. Can you confirm the model number as HD52W58 please? I will double check the requied parts and update this.
Thanks,
Dan
Sep 03, 2008 | RCA HD52W58 52" TV
Sony projection tv double vision
2 STK- they are big and black theses are your convergence ics.
Mar 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Curved picture and double images
I had noticed your question before posting mine, since it appears no one had given you a solution thought i would share the solution given to me. Two different techs told me the same thing it would need a new convergence board. I ordered my board today hopefully have fixed soon as it arrives. I noticed your question has been hear awhile but thought maybe if you still needed some help I would share. It is going to save me $300 doing it myself, but if you are going to try make sure to talk to one of the techs first on live chat. Goodluck
Sep 02, 2006 | Samsung PCN5425R 54" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
105 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
