Question about Gateway 7330GZ Notebook
Power jack repalcement Gateway 7330GZ Notebook
How do I replace the power jack in my Gateway Notebook model 7330GZ
  • mavi672000 Nov 22, 2008
    heloo i have a gateway 7330GZ notebook and i thought that my ac power was damage but i tried others ac cables and doesnt work i called gateway and the tall me that is better to buy a motherboard o i have to buy only the power jack idont know what to do because the computer was working fine
  • 39 Answers
You have options....#1 send it out to gateway for an arm and a leg...(i have the same model and had the same problem), #2 find a local computer repair store...they will most likely charge about 30 for the part.(that's what i was charged + 60 an hour for labor took 2 hours...) or #3 do it yourself, if you can solder then i can talk you through most of the dis assembly..plus you can get the part remarkably cheaper
Posted on Jan 15, 2009
A techie told me that the reason my Gateway 7330GZ notebook will not power on is a faulty power distribution IC on the motherboard. The part is impossible to find in my part of the globe (Nairobi, Kenya)...
You need to replace the motherboard. This may not be a cost effective solution.
It may be better to put your money towards a new laptop which will be faster and most likely slightly more than the cost of repairing the Gateway.
You can remove the hard disk from the Gateway and put it into an USB hard drive adapter case and then use it as an external USB hard drive for backups and data transfer.
May 23, 2011 | Gateway 7330GZ Notebook
The momentary switch on my Gateway 7330GZ laptop is defective. If I can slide it to the proper location, it will work. How do I remove the display portion to access the screws to remove the top panel and...
Here is a video on how to open the monitor on a Gateway notebook, although if the switch isn't working anymore I assume there is a part of it broken inside and you might need a replacement.
Dec 07, 2010 | Gateway 7330GZ Notebook
Laptop will not come on. Indicates that it is connected to power source although it is loose. What should I do? Is it the motherboard or the d/c adapter? I have a Gateway 7330 GZ.
Try another 19volts adapter. If problem still the same and the laptop not powering-on, there's something wrong with the motherboard circuit and not the DC JACK cause it indicates that you connect an adapter.
Apr 05, 2010 | Gateway 7330GZ Notebook
I have a gateway 7330GZ and I need to replace the CMOS Battery. Where is it located and how do I get to it?
the battery is located at the motherboard. you will see a big round battery like a watch battery but 5 times bigger,
open the CASE and you will see it shinning !! you need a tyny screw driver to remove the battery. you can get a replacement online by typing the model of the battery o take it to CVS they carry it
Oct 08, 2009 | Gateway 7330GZ Notebook
Gateway 7330gz will only run few seconds then turn off
Remove the battery and run off of the A/C power adapter without the battery installed.
If it works, the battery is just discharged too much. After Windows settles, insert the battery and let it charge.
Sep 09, 2009 | Gateway 7330GZ Notebook
Can someone provide me online recovery disk of gateway 7330gz
You must set the boot sequence of the system to cd/dvd rom first which will enable the system to look for booting files in the disc in the first instance.
In your case your system is booting direct from hard disk. Boot sequence can be changed ib the bios setup of your system.
In some laptop models the restore files can be accessed by pressing function keys while system starting.
Mar 12, 2009 | Gateway 7330GZ Notebook
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
Look for cracks in the hinges. It is a big problem with the Gateway 7330GZ.
Sep 30, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ- PArts needed
Those cables are custom made for each manufacturer and model. The only place to get a replacement (other than buy a junker on ebay) is from the manufacturer. The plastic pieces are another matter. They are standard connectors and you can buy them from Digikey or Mouser. Soldering them in place is not for a novice. You need a proper soldering iron, desoldering tool, very fine solder and a lot of patience and skill.
Jun 20, 2008 | Gateway 7330GZ Notebook
Screen problems
Try the power save options.
Nov 13, 2007 | Gateway 7330GZ Notebook
Computers & Internet Logo
437 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
