Question about Canon SmartBase MP360 All-In-One InkJet Printer
Getting a 5100 printer error
Full size text pages print OK, but when trying to print a 4x6 photo, the printer will print about 3/4 of the picture and then stop. I will either get a
ink cartridge jammed or it will display a 5100 printing error.
  • Anonymous Mar 14, 2014
    Printer will not print 8 x 10 photos. Only print 4 x6 & 5 x 7 photos.
  • 4,041 Answers
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Rollers won't pick up photo paper.
Hi I would suggest you to try once again by putting the shiny side up and print it again, some time even if the pages get stick with each other than also the printer wont take paper in. so try one more time and do reply if you still have the same problem or nay other.
Naiven.
May 31, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Hp 7960 printer
Make sure the paper try is properly attached. Try to unplug the power of your pinter and the USB cable for about 2-3 minutes. Restart your computer. Plug the USB and power to the printer then turn it back on.
Oct 04, 2008 | HP PhotoSmart 7960 InkJet Printer
When I print pictures on the 3210 HP all-in-one, they come out very small even though I choose the 4X6 in paper size for the photo tray. I've tried everything I can, but the pictures keep printing wallet...
First thing that comes to mind is that a 4x6" print could print four wallet sized photos; be shure your are not printing more than one copy.
If you are trying to print more than one,it will print the actual picure you have and leave space for the number of other nonexistent prints selected.
See page 75 of the Manual. for directions on how to set up photo printing.
If you have photoshop, you can resize your documents using the menu item, Image / Image size, (Alt + i then i again)
Set the resolution to 300, then the document size width to 6 or 10 inches.
This will guarantee that your document is full size, (though the printer should be able to resize it to fit on the page no matter what).
Give these a try. It's really a shot in the dark, but it's my best guess.
Cheers.
Richard.
Oct 13, 2009 | HP LaserJet 3200 All-In-One Printer
Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
At the printer:
1. Remove any paper from the input tray
2. Put a few sheets of 4x6 (10 or so) in the same tray
3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
On the computer:
Open a picture
Seect [File] [Print]
Select the photo printer from the list
Cick on [Preferences]
See the paper type? select photo paper
See the paper size? Select 4x6
Quality (Best)
[OK]
[PRINT]
Sep 28, 2009 | HP Office Equipment & Supplies
How do I print 4x6 photo on 8 1/2 x 11 paper?
Easiest is to open your photo with 'Windows Picture and fax viewer', follow the prompts, and the final window will give options to print "full page', Wallet size" 4"x6", etc
Mar 01, 2009 | Epson Stylus NX400 InkJet Printer
Printing 4x6 photos on photo paper
Sorry but your question seems to be unclear.
Here are the solutions that I see:
- try fixing the orientation of your paper on the printer:
-- go to printer "properties" then select "paper" then set it to
landscape or portrait. You might just have to cut the extra
papers
- try changing the paper size on the printer "properties" if it has
no 4x6 then choose "custom size"
Jan 19, 2009 | Samsung CLP 300 Laser Printer
Only 4x6 tray prints clearly
For this concern try pressing "copy+cancel" for media calibration then try again, make sure you have an A4 paper loaded. If this doesnt help you out try using the Kodak website www.kodak.com/go/itg and use "image quality" for class.
Oct 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer size small
Go to printer preferences and settings and put the right setting there.
Also in your document check the margins and print preview
Oct 13, 2008 | Dell 1700n Laser Printer
Printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
Mar 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Dec 27, 2007 | Samsung CLP 300 Laser Printer
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
52 people viewed this question
old marine
old marine
