Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Status codes How do I view the system status oceds? When the TV was recently serviced the technician displayed the TV status codes. This was accomplished using the remote control. What are the codes and what is the sequence to view TV system status? Are there other coded that will allow me to view TV status and logged problems? I have posted two intermittent problem with this model and would like to view codes when the problem occur to see if there are any "soft" or "hard" codes. Finally, how do I rest the status codes?
  • sheffy fields Nov 04, 2006
    Thanks for the info. However, nothing in the way of malfunctions came up. How to I get into the service area? Also, the linkhttp://myweb.accessus.net/~090/sonyadj comes back as not found. Any other ideas. Thanks again.
    Shef
    President:
  • 3,130 Answers
Go to http://www.techlore.com/article/15444/ This article has everything you will need. Also check this out.http://myweb.accessus.net/~090/sonyadj.html Good Luck and please dont forget to rate this thread.
Posted on Nov 03, 2006
SOURCE:
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
movement using the cycle selector knob.
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
RESET - Rotate cycle selector knob
counterclockwise one or more clicks
to clear sequence.
a. Rotate cycle selector knob clockwise
one click and wait ½ second.
b. Rotate cycle selector knob clockwise
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
clockwise one click.
?Successful activation of Diagnostic Test
Modes will be indicated by all status
LEDs (except for Lid Locked) flashing
ON and OFF in half-second intervals.
NOTE: LED names may vary between
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
Tip
Nokia Mobile Phones Security/Secret/Unlock codes
Nokia Mobile Phones Security/Secret/Unlockcodes.
The Codes shown below may not work for some models but these codes would work with almost all nokia mobile phones. These codes might not work on some of the newly released models. It's good for us to keep these codes handy. I have tried with several models but I couldn't try on all the models since I don't have all the handsets with me. I am still doing research with all the nokia mobiles so that we can use the codes better when we actually need them without using software or any kind of hardware to reset or unlock or to ask around here and there. Well let?s start with the default security code. 12345 is the default security code for all the nokia mobiles. To use this code, we need to go to the settings and select the appropriate security where you want to apply. Generally we use this code to reset the phone settings to default (Restore Settings).
Let me type down the codes and their respective descriptions:
  1. *3370# is to activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but battery talk time is reduced my approximately 5%.
  2. #3370# is to activate Enhanced Full Rate Codec (EFR).
  3. *4720# is to activate Half Rate Codec (HRC) - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
  4. *4720# is to deactivate the Half Rate Codec.
  5. *#0000# or *#9999# displays your phones software version, Software Release Date and Compression Type.
  6. *#06# to see the IMEI number (International Mobile Equipment Identity) [This number is unique for all handsets]
  7. #pw+1234567890+1# displays Service Provider Lock Status. (press "*" button multiple times to obtain the "p? , ?w" and "+" symbols).
  8. #pw+1234567890+2# displays Network Lock Status.
  9. #pw+1234567890+3# displays Country Lock Status.
  10. #pw+1234567890+4# displays SIM Card Lock Status.
  11. *#147# or *#1471# displays the last received call (only with selected Service Provider).
  12. *#21# displays the recent diverted calls.
  13. *#2640# displays the security code which is being used.
  14. *#30# displays the private number.
  15. *#43# displays the call waiting status.
  16. *#61# displays the number which "On No Reply" calls are diverted to.
  17. *#62# displays the number which "Divert If Unreachable" calls are diverted to.
  18. *#67# displays the number which "On Busy Calls" calls are diverted to.
  19. *#67705646# removes operator logo on particular models.
  20. *#73# resets every phone timers and game scores.
  21. *#746025625# displays the SIM Clock status, if your phone supports the ?Power saving feature? "SIM Clock Stop Allowed", you will get the best standby possible time.
  22. *#7760# displays manufactures code.
  23. *#7780# restore factory settings. (you?ll loss all your contacts and sms saved on our phone by doing this).
  24. *#7370# or *#7730# will format the phone memory. You'll need to enter the security code.. i.e. 12345.
  25. *#92702689# displays: Serial Number, Date Made, Purchase Date, Date of last repair (0000 for no repairs), Transfers User Data. You can?t exit this mode without turning off the phone.
  26. *#94870345123456789# clears the PWM-Mem. (Flash memory)
  27. **21*your desired number# turns on "All Calls" to be diverted to the phone number entered.
  28. **61*your desired number # turns on "No Reply" to be diverted to the phone number entered.
  29. **67*your desired number# turns on "On Busy" to be diverted to the phone number entered.
Some of these codes may work on some models and some may not.
If anyone could add more codes, please add them as your comment so that we can work better and help each other.
Thanks.
on May 11, 2010 | Cell Phones
Tip
Nokia Default Codes Most Nokia phones have the same default codes.The default...
Nokia Default Codes
Most Nokia phones have the same default codes.The default code is entered for the first time on a new Nokia phone and it won't be accepted if the default code has been changed by its owner.
Here are some default codes;
  1. Security Code: 12345
  2. Phone Lock Code: 12345
  3. Standard Bluetooth Pairing Codes: 0000
Nokia Secret Codes
There are a lot of secret codes on the Nokia phone and I'm sure you are aware of it or even know some of it. The listed codes below may NOT work for all the Nokia phones or it is restricted to some Nokia phones but you can try it on your phone to find out.
Here are some of the useful codes:
  1. #pw+1234567890+1# : Information about Provider Lock Status/Sim Restrictions.
  2. #pw+1234567890+2# : Information about Network Lock Status.
  3. #pw+1234567890+3# : Information about Country Lock Status.
  4. #pw+1234567890+4# : Information about Sim Card Lock Status.
  5. *#06# : Imei number (International Mobile Equipment Identity) or serial no.
  6. *#7780# : To reset the phone to factory settings.
  7. *#7328748263373738# : To reset the phone's security code.
  8. *#92702689# : Details about the phone: Serial no, month and date produced, the date the phone was purchased, date of last repair (0000 if not repaired at all).
  9. *#0000# : software version.
  10. *2820# : To add Bluetooth Device.
  11. *#7370# : To reformat the phone or Hard Reset (usually for Symbian phones).
  12. *#99# : GPRS Speed dial Code.
  13. *#746025625# : Details about the Sim Clock Allowed Status.
  14. *#7370925538# : To Reset Wallet Code (usually for S60 phones)
  15. *#3925538# : To Delete All Content in Wallet (if it ask for the phone lock code enter your phone lock or the default phone lock code).
  16. *#9999# : Details about the software version if *#0000# doesn't work.
  17. *#2640# : To display the Security Code in use.
  18. *#73# : To Reset the phone's time and also the game scores.
  19. *#7760# : To display the Manufacturer code.
  20. *#8110# : Details about the Software Version for Nokia 8110.
  21. *3370# : To activate Enhanced Full Rate codec (EFR) (which means your phone will use the best soud quality but the talk time is reduced to 5%).
  22. #3370# : To deactivate the EFR.
  23. *#4720# : To activate Half Rate codec (which means your phone will use the lowest quality sound but you would get 30% more of talk time).
  24. *#67705646# : To remove Operator Logo for Nokia 3110 and Nokia 3330.
  25. *#43#: To view the Call Waiting Status on the phone.
  26. *#30# : Enable to view the private number.
  27. *#21# : To check numbers that All Calls are diverted to on the phone.
  28. *#61# : To check the numbers that On No Reply calls are diverted to.
  29. *#62# : To check Divert If Unreachable/No Service calls are diverted to on the phone.
  30. *#67# : To check that On Busy Class are diverted to.
on Mar 15, 2010 | Rock & Ice Climbing
The status light just blinks and tv doesn't come on
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 03, 2012 | Mitsubishi Cinema WD-82740 82-inch 1080p...
What does it mean when the status light is blinking red on my mitsubishi wd-62526
When the status light is blinking push the device and menu buttons on the tv at the same time and hold for 5 seconds or more. The red light will then blink a code. It will blink like 3 times, pause, then blink like 5 times. That would be a code of 35. It may blink one time long, then two short blinks. That is not a code blink but indicates another problem. Do a search for the service manual for your tv on the internet and look up the code. Sometimes it is as simple as a dirty fan that won't turn any more. But by knowing the codes you will know if you need a technician or if it is something simple.
Oct 07, 2011 | Mitsubishi WD-62526 Projection TV
Tip
The Nokia Codes of most Nokia phones
Nokia Default Codes
Nokia Secret Codes
on Mar 12, 2010 | Cell Phones
Code 28
Code 28 Error Message
The Code 28 error is one of several Device Manager error codes. The Code 28 error will almost always display exactly like this:
"The drivers for this device are not installed. (Code 28)"
Details on Device Manager error codes like Code 28 are available in the Device Status area in the device's properties: How to View a Device's Status in Device Manager.
Aug 23, 2011 | HP Computers & Internet
I need to know the service mode of JVC TV flat screen
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
Mar 18, 2011 | JVC AV-32S575 32" TV
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Apr 20, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
184 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
