Question about iRiver X20 MP3 Player
Iriver X20 won't read on Iriver plus 3
When i click on Data transfer down the bottom left it says 36% full and that its in standby or something. The video tab isn't ther either.
Th
  • 49 Answers
This is a major problem i found with iriver plus 3. it tends to stall quite regularly. i suggest using wmp11 its just as effective. it cannot convert files but it syncs up quite nicely
Hope that helps!
Posted on Apr 25, 2009
Iriver plus 3 not recognising iriver x20 player
try to upload the songs onto it with windows media player 11 i only use iriver plus 3 for videos
when ur in windows media go into sync then it has like a side bar just drag the music into that and down the bottom of the bar it says sync press that
and if that doesnt work u might have to buy a new one
Aug 29, 2009 | iRiver X20 MP3 Player
Same happened with me, after mac connection
ok, plug it into the pc and run iriver plus 3, if you dont have it, you can download it from the iriver website.
then you connect the iriver.
then open tools>Portable Device>Disk Initialization..
this should format your iriver and give it default settings.
hope this helps you!
Jun 18, 2009 | iRiver X20 MP3 Player
Song names in X20
i think you should try this...
if you dont already, download iriver plus 3
install it
open iriver plus 3
plug in iviver
go to tools>Portable Device>Disk Initialization
this should format your iriver and replace all the original files
i reccomend only putting music, video, pictures and ebooks on via iriver plus 3
and also please make sure you safely remove the iriver each time you connect it to the computer
if you dont, there is a chance that you will screw your iriver, you may have heard of the "building library" problem, which nobody has found a solution for yet.
i hope this helps you!!
good luck!
Jun 06, 2009 | iRiver X20 MP3 Player
Iriver X20
can you connect it to your computer?
if so then format it then run iriver plus 3
plug it into the computer
then go to tools>Portable Device>Disk Initialization
if you cannot connect your x20 to your computer
there is a tutorial on the iriver support page saying you can format it by,
holding down menu butting and turning it on
but that didnt work for me..
otherwise, its stuffed..
if its stuffed, dont throw it away, ill buy it off you..
contact me if your interested, deano_90@hotmail.com
Apr 26, 2009 | iRiver PMP-120 Digital Media Player
Accidentally formatted my x20, now OS Vista does not see x20 when plugged in. Is there any way to reinstall the firmware?
firstly reformat the x20 using the device itself...
after that install the iriver plus 3...
there should be something on the program to reinstall it...
i also think that on the disc that comes with the iriver, there is an install that might help...
otherwise try and reformat the comp
Good Luck...
Aug 07, 2008 | iRiver X20 MP3 Player
IRIVER X20
you need to download the files onto your comp and then use wmp 11 and sync..
if u need to change formats of the music, video or pictures use iriver plus 3 that came with the product
Jun 02, 2008 | iRiver X20 MP3 Player
How do i add album art to iriver x20?
if your using wmp11 you should just be able to drag and drop.
if not right click the song/album and go to advanced tag editor, pictures and then add manually.
half the time it just wont come up because the tag doesn't read properly and the other half the album art that wmp11 downloads and applys automatically will come up!
its kind of up to chance! if you're lucky it works if not live with it its the X20!
ps the iriver plus 3 and itunes also can apply album art
Feb 23, 2008 | iRiver X20 MP3 Player
Transferring recordings from iRiver x20 to PC
Yes, it should work if you connect to the pc then click on my computer> iriver> then find the recordings and copy and paste them to a folder on your computer.
Jan 05, 2008 | iRiver X20 MP3 Player
Iriver X20- playlists and videos
yeah, basically all i did was change my settings to MTP.
then i went into internal hardrive (just in normal usb mode)
i selected the songs i wanted and right-clicked (make sure to do this one one of the songs you selected) in the options that come up it should say "create playlist" (in bold) i clicked that, it wouldn't let me rename the playlist... but it worked fine... and now they come up in the right place, i didn't even use Iriver plus 3.
Nov 22, 2007 | iRiver X20 MP3 Player
IRiver X20 won't boot
first try to go through the iriver plus program and see if there's any tools that can help. or reformat through your computer!
try copying the system files onto something then delete all your media files usually the library is just too big....
i had this problem once and i removed the battery as it was loading and the next time i booted it, it worked =). (this is worst case scenario though, you might end up screwing up the battery)
GOOD LUCK!
Oct 20, 2007 | iRiver X20 MP3 Player
iRiver X20 MP3 Player Logo
127 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
