Question about Philips 42FD9954 42 in. Plasma HDTV
42FD9954 philips plasma TV flashing LED it wont come on
Hello
I have a 42 in plasma TV but when I turn it on the LED light will go green like it will come on then after 7 or 10 seconds it will start flashing orange and it will not turn on
  • 2 more comments
  • Awsomeone Nov 13, 2008
    to tvjohn
    what do you mean by replace all the electrolityc caps in the power supply?? do you mean the capacetor??? thank you so much
    to tvjohn
  • jorichards6 Dec 04, 2008
    No picture at all. Green light comes on then flashes red - no picture comes on.
  • Anonymous Mar 24, 2014
    replaced blown fuse on main board now when i turn on tv green led comes on screen comes on for 1 sec then tv turns of
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Posted on Nov 15, 2008
  • Rick Feb 13, 2012
    Good call. Heating the power board with a hair drier enabled the set to be turned on and function. I replaced capacitor 2503 but hasn't fixed the problem. Any suggestions as to which alternative capacitors might be looked at ?
    (My 42FD9954/ 69C is now 7 years old)
  • 70 Answers
Start by grabbing a hair dryer and warm up the power supply board.
If the set starts then replace all the electrolityc caps in the power supply.
If this does not cure the problem then check the y sus board and the z sus board.
Posted on Nov 10, 2008
My Plasma 42FD9954 42 TV doesnt work
Familiar problem on Philips Plasma units. PSU or Sustain board failing.
Jan 16, 2013 | Philips 42FD9954 42 in. Plasma HDTV
I have a phillips 42fd9954 17s. when i turn it on the green light tuns on for like 6 seconds then fades . then nothing. no sound no picture. any idea. i am using a comp cord. had no cord when i got it
if you use vga input and there is no signal the tv shuts down in few second. It will wake up again if you provide vga signal or cycle it on off again. Change input to component or s-video and tv should stay on. On the other hand, this model has known problem with bad power supply unit but usually red light flashing when tv shuts down in that case.
Oct 16, 2011 | Philips 42FD9954 42 in. Plasma HDTV
Philips Plasma NO LIFE
Are all the caps good on the PSB.? Most sets have Samy boards and they used very shotty capacitors. Some show NO visual clues of being blown as in poped at the (X) top. They just vaporize/dry out. Do you have a cap tester?
Best Regards and Semper Fi
Feb 08, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Red light is flashing
I've done extensive "google" research on this issue, and often it seems to be a problem with the capacitators. Philips uses cheap parts that "overheat" and go bad.
Dec 20, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips 42fd9954-175
Hi, and unfortunately I am facing the same issue. My TV blinks GREEN LED for a few seconds then starts flashing RED led. The result I hear from this is that it is the SSB Panel and the estimated cost for service is $600.00 it sounds like you are STARTING with the problem. I began that way too. If you are under warranty, call Philips NOW!
May 13, 2008 | Philips 42FD9954 42 in. Plasma HDTV
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
Dec 21, 2007 | Philips 42HF7444T 42 in. Plasma TV
Philips 42FD9954 42 in. Plasma HDTV Logo
890 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
