Question about Onkyo HT-S770 System
No Sound coming from speakers
I'm not getting any sound from the speakers. It was working fine. i've checked all the connections and reseted receiver to factory default. When i assign V1 an optical input, i have no options for listening modes. it displays "Not Available". Has never happened. so i tried the FM Tuner, which doesn't require an outside source. Nothing. Speakers work, tried them on another receiver. i only get any kind of option for the mode after toggling the speaker "A" channel off and on. then i get a choice of DTS or STEREO. Neither speaker channels, A or B, work. I am completly stumped. Any options, tests or suggestions welcome.
  • Official Brand Answer
  • 333 Answers
Can you please provide your model number. Thank you, Onkyo USA.
Posted on Apr 10, 2017
3 Suggested Answers
SOURCE:
asnowman
  • 788 Answers
SOURCE: ONKYO HT-S780 B SPEAKERS
Your symptom sounds as though you may have to turn off any surround sound settings that you have selected in the other modes.
Most amplifiers use the surround portion of the amplifier to power the B channel speakers.
Since you have sound when using the radio portion, I would try turning off the surround mode. For example try turning the amplifier to just stereo and see if that gets the B channel speakers to work
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 22, 2009
thadrizzle
  • 22 Answers
SOURCE: I am not getting the full surround sound options.
On the remote try scrolling through the settings from the DTS button and also make sure you have the correct audio source selected. I switched to the optical cable but, then found that the better sound for my room came from the RCA set-up.
Good Luck and I hope this helps.
Posted on Oct 04, 2009
I have a sony str-de 998 receiver,and there is no sound coming from the surround speakers. i have tried resetting ,but it doesn't help.any suggestions?
Your Sony receiver may have to be configured to use the surround speakers. This is accomplished as part of the set up process.
Sep 06, 2014 | Sony Audio Players & Recorders
Sound comes through only one speaker at a time.
Is the sound on both channels on a pair of headphones? If it is suspect a faulty headphone socket, especially if the speakers are cut out when the headphone jack is inserted - normally.
Jun 15, 2013 | Technics Audio Players & Recorders
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
What does check phase mean? Must have something to do with the sound since I am not getting any from any source except am/fm but only out of one front speaker.
Hello
There is tow leads for every speaker. Out of which, one will be marked [+ve] and the other will be negative. The negative terminal of the speaker should coincide with the negative terminal of the respective output terminal from the amp. For the other speaker also, this must be the same with respect to connection. If any one connection in one speaker has been reversed, the sound effect will be effecteed. When we connect in phase, that is [+ve] and [-ve] correctly to both speakers the sound effect will be great. If one among them is reversed, the effect of one speaker will neutralise the other, and the sound spectrum also will be neutralised. Checking this connection whether it has give in correct way is calle "check phase'. OK.
Jun 21, 2011 | NAD T755 Receiver
Only 2ch sound on sony strde898
I understand that you have tried connecting different audio source to the Receiver as some of the audio source will output only 2 channel audio. I hope you have tried changing the Input mode and Input selector to get the surround sound.
Please disconnect the speakers with the receiver and clean the edges of receiver and speaker cables using solution like alcohol and try.
If the issue persists, please interchange the rear speakers with front speakers and vice versa and check if audio is coming to make sure that the speakers are working fine.
If the audio comes after replacing the speakers but not from surround speakers, the receiver requires service.
Sep 22, 2009 | Sony STR-DE898 Receiver
KD-LX100 working fine, then CD sound stopped working.
That particular cd might have been damaged .
Have you tried with any other cd .
Nov 27, 2008 | JVC KD-LX100 CD Player
System was working fine and now there's no sound, but deck still does everything else.
The speaker wiring might be damaged. ( cauese :- Wires getting caught to door, Heavy weights can also seperate wires by breaking them ).
PLEASE RATE ME AS ( FIXYA ) <BLUE BOXES>...............
May 27, 2008 | Alpine CDA-9830 CD Player
Denon AVR-3300 Center Chanel Sound Problem
My guess is You have dried out electrolytic capacitors causing failure. These receivers when they get over 6 years old start drying out fluid in capacitors especially on regulator p.c.b. causing noisy supply lines. I work for Authorized service center in Michigan If you need repair and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 06, 2008 | Denon AVR-3300 Receiver
Onkyo HT-S770 System Logo
49 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
