Question about Plumbing
4 hp Briggs Horizontal engine
I think the flywheel key may be partially sheared, causing the timing to be off. I have backfire through the carb. This is a wood splitter that I over-worked recently.
I installed a new solid state magneto and have good spark.
Question: How do I replace the key? Are special tools requited?
    Scholar:
  • 36 Answers
On your flywheel there should be 2 holes threaded on the top area & the retaining nut in the centre.
remove the centre nut completely, then get a flat piece of steel bar (about 6" long x 1/2" thick x 11/2" wide) drill 2 holes (clearance holes) at the same distance as the ones on the flywheel.
then drill one in the centre about 1/4" dia.
Get two bolts that will fit into the 2 threaded holes & pass then through your newly drilled bar.
Place a ball bearing on the centre hole & tighten your 2 bolts inwards.
When they both start to get tight tap the flywheel with a hammer & tighten futher on the bolts.
The flywheel should now come loose.
Posted on Nov 27, 2008
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & stratton 5hp motor will not start
Check the flywheel key, it may have sheared. If the key shears it will throw timing way off. This would cause a backfire or "pop". Start there and let me know, Daniel
Oct 22, 2012 | Garden
My B&S 18hp Intec engine on my lawn tractor will not start but it will backfire??? Will not run
You may get lucky and have a sheared keyway on the flywheel . Just a lil off can make a big difference on timing.
Jul 28, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Tecumseh OV691EA engine Carb spits, crankshaft stops when cylinders fire. Compression L-95 R-110
When you say crankshaft stops when cylinders fire I am assuming this is during start. This is caused by a flywheel key problem (Partially sheared) A flywheel key will partially shear if there was a sudden stoppage of the engine. I e. you hit something that stopped the blades right away.
Service manual is here:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_V_TWIN_ENGINE_696325.PDF
Flywheel removal is on page 44 of the file.
I am pretty sure you have a flywheel key problem as this appears to be an engine timing problem and it is firing too soon. (again partially sheared flywheel key causes timing to advance. If there is not a problem with the flywheel key the next suspect would be the mechanical compression release.
A note about flyweel key replacement. Most of them are aluminum or soft metal so that the crankshaft does not shear off with a sudden engine stoppage. Just make sure to use a Tecumseh
replacement flywheel key and not one from an auto parts store.
Thanks for chooding FixYa,
Kelly
May 19, 2011 | Garden
Briggs and stratton engine on my lawn mower won't start.
Remove the blade and check the keyway. If the key way has the shear pin still in it it may have been bent and not sheared off. That will cause it to be off timing. I would imagine the valves got bent from the sudden stop of the engine as well
May 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Backfires thrue carb
You may have an intake valve staying open or the spark timing may be off from a slipped flywheel and key. Can spray liguid wrench in the intake to coat valve stem . You would have to take off the flywheel hold down nut and pull starter engage ring to see if the groove in the flywheel matches the groove in the crankshaft. Ive had blowers, weed eaters, tillers and all kinds of small engines break a flywheel key for no apparent reason. Sometimes they are just a little loose and wear out or snap.
May 09, 2010 | Briggs & Stratton Intek Snow Horizontal...
Backfires through the air cleaner
This usually means a bent or sheared key in the flywheel. Remove the shroud exposing the flywheel buy a 6" flywheel puller and remove the nut for the flywheel and attach the three jaw puller remove the flywheel and replace the flywheel key. The only other thing that causes this popping through the carb is a burnt intake valve this is a job for a lawn mower shop.
Sep 30, 2009 | Garden
Plumbing Logo
147 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
