Question about Pool & Spa
JandyColors Digital Color Pool & Spa Lights
The lights for my pool & spa will not cycle through the color changes. It stays on the white light.
  • David Spradling
    David Spradling Nov 10, 2017
    make sure in set up you have picked that model light
    Top Expert:
  • Pool & Spa Master
  • 7,228 Answers
Make sure in system set up you have in lights that checked then should work make sure not wired with dimmer
Posted on Nov 12, 2017
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
PartsCenter
  • 125 Answers
SOURCE: Jandu Aqualink Pool/Spa Controller RS6
AQUALINK GUIDE BOOK
PartsCenter
  • 125 Answers
SOURCE: We just moved into our home and there is no manual
Here is a link for the Manual and trouble shooting guide. Aqualink
Posted on Mar 04, 2009
rcampsr
  • 90 Answers
SOURCE: Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Posted on Apr 20, 2009
Can I replace a non color changing spa light without draining the spa?
All the free standing spas I ever worked on, all the lighting & controls are accessable through the cabinet of the Spa. The "In ground" spa lights are pretty much treated like a pool light. whereas the light fixture is in a housing that is normally unscrewed from the top of the mounting ring & with a little "tip & lift" housing & cord come out of the water
Dec 10, 2013 | Pool & Spa
I have two LED color lights in my pool. 1 changes color but the other does not
Your post did not specify the brand of pool lights you have, but assuming they are Hayward, it sounds as though the lights are out of sync... that is, one light is running a different program than the other. If both lights are controlled by the same on/off switch, this is a simple fix; If they are on separate switches you would use the same procedure, but then BOTH SWITHES must be toggled AT THE SAME TIME. To re-sync your lights, turn both lights on and, if necessary, wait for the15-second full-white period to elapse. Next, turn both lights off and wait no less than eleven (11) seconds, but not more than fourteen (14) seconds before switching the lights back on again. Remember... if each light is controlled by a separate switch, then both switches must be toggled "on", "off" and then "on" again at EXACTLY the same time. If the lights are operated in this sequence within the 11-14 second window, they will both automatically revert to full-white light for 15 seconds and then reset to program one. From that point on, as long as you switch the lights on and off at the same time (to cycle through the color programs), they will remain in sync. Good luck.
Dec 13, 2010 | Hayward 12v LED Color Logic Pool Light...
I have 2 light colors in my pool in one of them When I turn them on one just flashes
LIGHT SYNCHRONIZATION If your pool or spa has multiple Hayward ColorLogic LED lights, they may be operated independently, or they can be easily synchronized so they will all display the same colors and shows at the same time. For light synchronization, all lights must be wired to the same switch. Once installed, all lights should be automatically synchronized, however, if they get out of sync, they can be re-synchronized easily. To re-synchronize your lights, turn the switch on, then back off, then wait between 11 and 14 seconds and turn the switch back on. When the lights come back on, they should enter program #1, and be synchronized.
Feb 15, 2010 | Hayward 12v LED Color Logic Pool Light...
Pool lights go on randomly--not programmed to go on at all
make sure the light is pluged in a port that is for like a spare aux. any time you add programs you must hit the store button.
Oct 05, 2009 | Jandy AQUALINK RS TELELINK KIT
Hayward Colorlogic Light flashes like a strobe
OK I GUESS U HAVE A AUTHOMATIC CONTROL CHECK T RELAY FOR 120 V THAN CHECK FOR V AT THE JUCTION BOX IF V LIGHT MUST BE REPLACE.
Jul 07, 2009 | Hayward 12v LED Color Logic Pool Light...
Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Jul 06, 2009 | Hayward 12v LED Color Logic Pool Light...
My Hayward Colorlogic pool light is flashing like a strobe light
That particular swimming pool light has a power-cycle feature that allows you to change the way your light illuminates your pool simply by turning it off and on. A strobe like effect is one of these power cycles. To change it, simply turn the switch off and then turn it back on within 10 seconds. It should reset to another cycle. It is is left off over 60 seconds, it resets to the first cycle, which could be the strobe. If cycling doesn't solve the problem, your bulb has probably malfunctioned and you are going to have to have a repair tech service it.
Jun 16, 2009 | Hayward 12v LED Color Logic Pool Light...
Multi color light will not come on/only flashes a second
These swimming pool lights are have a power cycle function. It could be that your power cycle is not working properly. Turn the light off for more than 60 seconds to let it reset. Then turn it on and off in 10 second intervals. If the color does not change or the light does not stay on, and you have tested your ground connection, then you will probably need to have your bulb replace.
May 28, 2009 | Hayward 12v LED Color Logic Pool Light...
Pool & Spa Logo
134 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
