Question about Mitsubishi VS-7083 70" Rear Projection Television
Picture Too Light
Just recently, whenever I first turn on the TV, although the picture is initially fine, it shortly become too light. It's as if I turned the brightness way up. At the same time, faint lines appear in the backround. After several hours, the picture darkens, and I can get it almost normal if I play with the contrast. However, when I turn the TV off and it is several hours until I re-turn it on, the problem starts again. Any suggestions would be appreciated. I have not yet called a repairman since I would like to have an idea of the problem first. Color and everything else is fine.
  • Richard Goldberg Oct 19, 2006
    Forgot too mention that the TV is a Mitsubishi, VS-7083 rear projection.
  • Richard Goldberg Oct 20, 2006
    Pushed down on every connection, and it seems to have done the trick. Thanks soo much for the immediate response and help.
    Sergeant:
  • 337 Answers
Not long ago I had my head inside one of those units,I was looking for something else but I did notice and repaired many loose conections and believe you have the same ,your problem is related to the screen voltage and a loose conection might be around the high voltage transformer.Please let Us know how it goes or if you need more information.
Posted on Oct 19, 2006
  • Omar Urrutia
    Omar Urrutia Oct 19, 2006
    Your rating response is also important.
  • Omar Urrutia
    Omar Urrutia Oct 20, 2006
    Glad to hear!!!something is loose and it need to be resoldered.
Sharp TV - no picture, sound is fine
Hope this is an LCD TV. If it is, show a torch light from a distance and see whether the picture can be seen. If yes, the backlight has gone bad. If no, try changing the input device to something you know works. If nothing works, this is a case for a qualified service technician.
Jul 28, 2012 | Sharp Televison & Video
My Tristar TV signal booster has a red light illuminated, I think is says 'short' above it. Is the booster working? I have fault on my TV it maybe this. The booster has been working fine up till...
I too have a red "short" light on my Tristar booster. However- I've illiminated the Tristar as I unplugged it and connected my tv directly to the 13amp mains and b) connected the aerial directly to the aerial wall socket which is separately boosted from a distribution amplifier box in the loft. Picture was U/S so the "short" is probably in my cabling in the loft (I've been moving the aerial about lately).Hence I suggest initially to unplug the Tristar and check the fault is not back further up the line ie the cable and booster at top of house. Hope that all makes sense.ps before noticing the red "fault" light, my picture had gone to pot.
Jul 18, 2011 | Televison & Video
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Loss of picture on Pioneer Plasma Tv
i have a pioneer 43 inch bought in 06. tv wont turn on light flashes red the light means standby. what does this mean
Jun 07, 2009 | Televison & Video
TV shows only a thin horizontal light whenever i turn it on
there seems to be a problem with the vertical deflection ic or deflection yoke . try resoldering the vertical ic joints look for other loose solder joints around the vertical area on the circuitboard
Nov 17, 2008 | Televison & Video
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Televison & Video Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
