Question about Health & Beauty
CHI Flat Iron GF-1001
Cause use of wrong voltage (220V instead 120V)Devise stop working.
Took it apart and there is one burned element on electronic plate
That element located next to HT-1and COM-1 contacts and has two legs soldered to plate , and there is a marking right next to it says TNR
Please tell me what is that element is so I can re solder one to fix it.
Really need it done for my wife birthday.
Thank you very much.
  • 4 more comments
  • rollright200 Nov 30, 2008
    I have a Chi GF-1001 flat iron also.. The problem is that it is getting power when it is tilted a certain way/ or I push arounf the pwer cord. I've ohmed everything up to the power connecting board and it is ok. I've noticed some burn marks around the switch. I'm still trying to figure out what is causing my intermittent power on/off situation..
  • akhargrove Dec 30, 2008
    I plugged mine in a converted in Europe and Farouk wont fix it...:(
  • Anonymous Jan 03, 2009
    I drop my chi and now it will not work. I have taken the chi apart and check voltage at the circuit board and have voltage there. i wonder if it is the fuse or ceramic element causing the problem. anyone have the same problem and how can i fix it.
  • Anonymous Apr 06, 2009
    Blew the capcitor on the underside of the board. looking for the size of this capacitor (120V lead power end of the board).
    Thanks in advance
  • ohbilly Apr 06, 2009
    Blew the cap on the underside of the control board. Please indicate to me the size of this capacitor (pF/ Voltage). Thanks in advance.
  • dfeijoo Apr 09, 2009
    Does anyone know the specifications of the capacitor???
  • 157 Answers
Hello alexkuzin, searching for tech info of the Farouk CHI GF-1001 flat iron is slim to none. The HT-1
is the high side of the 120v and COM-1 is neutral. The TNR will be the thermal resistor for temp regulation. If your 'burned element' is broken anywhere but at the terminal "sorry charlie" you are SOL. The TNR is in series with the heating element and if this is 'burned element" finding a replacement will be difficult. Contact your local appliance/electronics parts store. Oh,how did you insert a 120v plug in to a 220v outlet?
Posted on Nov 12, 2008
How do i open the chi to replace the broken power cord? I am unable to remove the screw that hinges the two arms? I removed the plastic tabs that hide the screw but unable to unscrew it. The screw serves as an axis. I am unable to hold the screw while turning the other end. There does not seem be another way to get into the arm that houses the electric cord. Also anyone know where find a cord replacement. My local appliance store does not carry the cord
Posted on Sep 18, 2009
I have a chi flat iron model GF 1001 USA The top does not heat up at all? What could be the problem?
The heating coils have went out on that side. Time for a new flat iron sweetie??
May 27, 2015 | Chi Health & Beauty
Can this be fixed? Who can fix it?
Is there a fuse on the iron? Is the transformer providing power now that its fuse has been replaced? If not, it could be that the transformer has blown which caused the fuse to go, this means a new transformer. If it is, then could be the element in the iron has failed. I don't know if it's possible to replace the element, but may be cheaper to replace the iron altogether.
Oct 14, 2014 | Chi Ceramic 1 inch Flat Iron GF1001USA
How do I fix Chi flat iron if it is not heating up?
Hi is there power to the element if there is then I would say the Element is to long new and needs a replacement
Hope this helps
Aug 16, 2014 | Farouk CHI Royal Treatment Gold Ceramic...
My chi just started to make my hair smell like its burnt. Ive had it for about a year.
Is your CHI overheating and burning your hair?
If you know what's wrong with it or what it's doing such as overheating then you could contact and see if it can be repaired.
Jun 04, 2012 | Chi Ceramic 1 inch Flat Iron GF1001USA
Thermal fuse on chi flat iron
Took my chi to Europe and despite having a converter that was supposed to step down the power from 220 to 110, my straightener fried. Doesn't turn on at all despite resetting the GFCI in the plug. Not sure if the issue is in the plug part or the thermal fuse in the body of the straightener. Though
Feb 05, 2012 | Chi Ceramic Flat Iron Gf1001
I have several "Chi" Flat irons that no longer
When the flat iron does not heat up, it is usually the ceramic fuse that is located under one of the heating elements. I fixed my daughter;s CHI flat iron for $1.97 with a ceramic fuse I bought at Radio Shack.
Oct 01, 2011 | Chi Ionic Single Pass 1 inch Ceramic Flat...
Where can I get my Chi Flat Iron fixed. I only used it 3 times but had the iron over a year because I have my hair ironed at the beauty shop due to its length. I bought the Chi to do touchups and am...
Chi Flatiron Repair Fix it Yourself User Photos
Most appliances come with manuals that give you company contact information. My guess is the iron is out of warranty. As irons have high voltage components, do it yourself is not advised. Staying alive is better than fixing an iron. That said, the above link even tells you how to take it apart. I have a hunch that good parts would have to come from another broken Chi iron. And where would you get that! Maybe someone on the above link can be contacted. Alas, you simply wanted a reliable business that might check this out. I doubt you want to pay a technician for his time in taking this apart. I wish you well.
Jun 04, 2017 | Chi Nano Digital Ceramic Flat Iron 1.25...
I have bought thermal fuses from DigiKey. They have various temperature ratings. If you have a multimeter or ohmmeter you can check to see if the fuse still has continuity. If the iron sometimes works, it's not the fuse. Cords are the most common problem, but if it was plugged into a 220V I'm not sure what might have gotten fried. There is a small IC in there too, for temp control or something: if it's fried you are SOL. Save it for parts though...
Nov 13, 2008 | Oster 76076-010 Hair Trimmer
Health & Beauty Logo
4,331 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
