Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Color ink not working
Like the black ink works and sometime its grabs the paper but the color ink doesnt work like cleaing it doesnt work i changed it already and when it prints theres some place where it has color but the rest is white
  • 34 Answers
It sounds like you need a new Printhead, not ink tanks. Part Number is QY6-0054-000.
Posted on Nov 11, 2008
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
My printer canon ip1300 dont print black color, only color is working, even the black cartridge is installed, it doesnt print black
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Jun 14, 2011 | Canon PIXMA iP1300 Printer
Printer not working so put new Color ink in - red light is on the black ink. Changed printing preferences to Color Ink and deleted all documents in queue and also turned off computer and still the printer...
part of your prob is that the way ink jet printers work, (according to the tech support training that I rcv'd about ten yrs ago from Canon) is that the printer "builds" the image or character by adding color to the black ink (for most of the jobs) in order to create "depth", so you will need to replace or (HINT: you can sometimes reset the cartridge by lifting the locktab and then reseating it) using the utility to replace the black cartridge. good luck!
Jun 13, 2010 | Epson Stylus 880 InkJet Color Printer
My Kodak ESP 3 black doesn't work. I have ran
It sounds like you need a new printhead. The Kodak ESP 3 works in two stages, you have a printhead which is what transfers the ink to the paper then you have the ink cartridges. Change the printhead. You can try to clean it also, by removing all the inks. Taking the printhead out and soak it it warm water to dissolve the clog. Sometimes it will work.
Apr 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
PAPER FEED DOESNT WORK KONICA MINOLTA COLOR PRINTER
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Mar 26, 2009 | Konica Minolta magicolor 2430 DL Laser...
A960 All in One Printer not working with color cartridge
My new black ink cartridge wasn't working at all. I sprayed the cartridge with windex and let soak for a minute. I wiped dry with paper towel and there was black ink on my towel unlike before. The windex unclogged it and it worked like new!
Oct 17, 2008 | Dell A960 All-In-One InkJet Printer
Canon i560s prints all colors except black
I had a similar problem and found out that you have to specify printing on plain paper. If you choose paper other than plain paper, it will make the black from other colors. Check also that all of your cartridges are seated properly. My magenta was not pushed all the way down so I got green instead of black ink when it mixed the colors to make black.
Jan 31, 2008 | Canon BubbleJet i560 InkJet Printer
Cengiz
could you replace the inkcartridge, it might be that the the black inkcartridge is the problem itself...
Dec 06, 2007 | HP DesignJet 450c InkJet Printer
Black ink not printing
To fix this problem I installed a new driver and switched the paper settings to high glossey paper...so far it works...black was the only problem...color printed fine.
Dina
Nov 22, 2007 | Epson Stylus C43SX InkJet Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
old marine
old marine
