Question about Casio XJ-S35 DLP Projector
Problem with Casio xj-s35 projector
Seems to be locked. fan on, led temp and lamp lights blinking, power standby non responsive. does anyone know how to reset.
    New Friend:
Hello, I have my one Casio -xj-M255 projector (LED) light incidence settings from the sky-rise I want to help you if I become a menmun to reset the lamp hour ?st?yorum
Posted on Feb 09, 2015
You have to disconnect power to reset it.
Posted on Mar 17, 2011
Optoma hd73 the temp light is red and wont start fans or light just the standby light on flashing could this be a ballast issue or thermal sensor?
if you projector auto shut down, and Lamp LED Light - Check Lamp - Check Lamp Driver - Check Main Board b. Temp LED Light - Check Thermal Sensor - Check Thermal Switch - Check Fan
May 12, 2016 | Office Equipment & Supplies
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
Projector problem HELP!? my projector was on whiles the utility power went out, and when the power came back i realised it had affected my projector, when i put it on (press the power button) the:...
Kindly get intouch with Cinesonic Audio Visual Pvt. Ltd. in New Delhi at 10/2, DLFIndustrial Area, Shivaji Marg, Moti Nagar,
New Delhi-110015
Contact: ' Board: +91-11-47424444 (30 Lines)'
e-mail: Robert@cavpl.com
For any problem related to Casio Projectors
Mar 21, 2011 | Casio XJ-S31 Projector
All the lights are on: power light, lamp light and temp light... How can I fix it?
If you have the manual you can look at the back for troubleshooting. The problem or solution will depend on if the lights are blinking and what color they are. The manual can be found here. You will want the basic operations manual.
http://support.casio.com/manualfile.php?rgn=1&cid=007001005
I just had a XJ- S41 projector in for repair because it wouldn't power on. The power light was red solid but the temp and lamp lights were blinking red. Apparently a reset was needed, but I was told it was an internal reset that had to be done be a technician. I'm dubious of this info as I've seen some reset procedures listed on this site that may have worked, but I can't confirm as I sent it in. It cost $45 plus shipping to have Casio do this reset and there was nothing wrong with the projector or any parts replaced. Casio wouldn't tell me exactly what reset procedure was done and they will not let you speak with a technician or even try and get more info for you. Using their online repair service though was easy and swift. Just go to www.ecasiorepair.com.
Nov 12, 2010 | Casio XJ-S31 Projector
PROJECTOR PROBLEM Casio XJ 31
it wasn't able to go through cooldown mode. turn it on, power down and let it go through cooldown. does the light come on at all?
May 31, 2009 | Casio XJ-S31 Projector
it wasn't able to go through the cooldown mode. turn it on and power down, letting it go through the cooldown mode. does the lamp come on at all?
Jan 22, 2009 | Casio XJ-S31 Projector
Problem with my dell 1200mp projector
if you haven't already try cleaninig the filters
Aug 22, 2008 | Dell 1100MP Multimedia Projector
SONY VPL-CS3
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
Casio XJ-S35 DLP Projector Logo
396 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
