Question about Acer Computers & Internet
My computer wont read disks it was able to a few days ago and i went to go put in a disk that needs to get installed before i can use a camera. I have tried others disks and it wont read any of them. Anything i can do to try or do to try and fix it?
    Problem Solver:
  • 5 Answers
You need to first check if the disk is being detected by Computer--
click start---computer ---check if the disk that u insert is visible there or not.
And also chk in device manager---by right click on computer--properties---device manager(vista)--look for cd/dvd drive.
right click on my computer---properties---hardware----device manager(xp))--look for cd/dvd drive.
If not visible in device manager then u have to open up ur computer and reseat the cd/dvd drive cables...
If its visble in device manager--then right click on the option under cd/dvd drive----properties----check for the error code.
If error code 19 , 31 , 32 , or 39 is displayed inside Device Status.
Then click start -- run -- and -- type regedit -- click ok . the registry editor appears.
In windows XP -- click file -- EXPORT-- TYPE A FILENAME THAT IS EASY FOR YOU TO REMEMBER AND CLICK SAVE.
A COPY OF THE REGISTORY HAS SAVED FOR BACKUP PURPOSE.
CLICK THE PLUS SIGN (+) NEXT TO THE FOLLOWING ITEMS IN THE LIST :
In Vista click:
HKEY_LOCAL_MACHINE
SYSTEM
CURRENTCONTROLSET (OR THE CURRENT CONTROL SET WITH LOWEST NUMBER IF THAT IS ALL THAT IS LISTED)
CONTRO
CLASS
SELECT 4D36E965-E325-11CE-BFC1-08002BE10318
SELECT THE UPPER FILTER IN THE RIGHT WINDOW AND PRESS THE DELETE KEY
CONFIRM THE DELETION BY CLICKING YES
SELECT THE LOWER FILTERS IN THE RIGHT WINDOW AND PRESS THE DELETE KEY
DELETE ALL OTHER UPPER FILTER AND LOWER FILTER VALUES WITHIN THE 4D36E965-E325-11CE-BFC1-08002BE10318 KEY
CLOSE THE REGISTRY EDITOR AND RESTART THE COMPUTER ...
This should resolve the issue...
Let me the the error code and msg in device manager window.....
Thank you ....
Posted on Nov 08, 2008
The disk plays fine in the camcorder, but not when I put the disk in a computer. I finalized the disk before i put it in the computer.I
you need to install the dvd playback software on the Pc to read the disk. the codec of the camcorder is not installed so the Pc can't read the video format. use for exemple dvdplayer you can download it from this link it's free: http://www.dvdvideosoft.com/products/dvd/Free-DVD-Player-Software.htm
Dec 24, 2010 | Canon DC20 DVD Camcorder
I just let my credit card information in a few minutes ago.i have a blank hard disk and am rying to install Ubuntu.iso on a hard disk using an emergency disk fom Windows to boot up the system with cd...
If you have the 'ubunto.iso' file, you need CD/DVD-writing software to read that ISO file, and to burn that image onto a blank writable disk.
Then, restart your computer, and change the "boot-order" so that the CD/DVD device is the _FIRST_ boot-device. Then, Ubuntu will boot-up, and you can "install" Ubuntu onto your disk-drive.
Jul 03, 2010 | Computers & Internet
It happened 2 me
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-27
Jun 17, 2009 | Nintendo Wii Console
My zen mozaic lx is not reading to my computer
okay, it is not reading because you need the cd it came with and download it onto your cpu.(it has to be the kind of disk port that comes out. if you have the disk port that you just put in, it wont work.) if you have a little computer, and no disk drive, then you have to buy a one that goes into usb.
Mar 24, 2009 | Creative Labs Zen V MP3 Player
Cant install program from DVD drive GWA-4164b
First check that your system meets the minimum requirements...ie. you have at least 512mb of ram, CPU of at least 2Ghz Pentium4 or equivalent(with off-board video), and your hard drive has >4GB of free space.....can view full list at:
http://www.amazon.com/Spore-Mac/dp/B000FKBCX4
Is SPORE on a duel layer dvd? If your drive is on the older side, you might try a newer one or you can try the following:
--take out an empty flash drive with
--go to a computer that will read the disk...if you have another computer or u can use someone elses
--put the disk in their computer and if the computer is able to read the disk, then put your flash drive in the computer and copy the disk onto your flash drive...
-y-ou can now try to install the program from your flash drive instead of using the disk...
NOTE: Trying this method wont cause any damage, but if the disk is encripted or if the install software is set to check for the disk during installation, then this may not work, but is worth trying since because a) even if it doesn't work, no harm is done, and b) you wont need to replace your disk drive if it does work.
Feb 12, 2009 | Acer (4432A-002) CD-RW Burner
My xbox360 wont play any disk
I had a problem like this a few days ago, my 360 had problems reading my disks. I ended up opening it up and cleaning the laser in the dvd drive. After that it played fine, if that doesn't work you might need a new dvd drive.
Jan 04, 2009 | Microsoft Xbox 360 Console
I have a pavillion 9000 with Vista home I started it up a few days ago and it didn't open normally It went into recovery mod. and started. At this point I lost one of my user accounts and my abillity to...
You system is infected with a potent antivirus, and cannot be resolve anymore by a potent antivirus.
So you need to reinstall your computer to the original setting:
By doing this : insert the windows installation disk/ or the system recovery disk.
reboot your PC from the CD/DVD rom and then wait until boot finish.
If you are using system disk recovery , just read carefully the instruction on-screen.
If you are using the windows installation disk then here is the windows installation information: http://support.microsoft.com/kb/316941
May this help,
melnavz
Oct 05, 2008 | HP Computers & Internet
CD won't eject....
you need cleaning and maintenance on your radio if you want to eject the disk theres a little tiny button on the face you will need a pin push it in and this should eject your disk
Sep 27, 2007 | Kenwood KDC-215S CD Player
Computers & Internet Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
