Question about Acer Aspire 5100 Notebook
Acer Aspire 5100
I tihnk it might be the graphics card, but when i start the computer, the monitor wont work. I just get a black scrren, and it stops booting. I got it from a friend and he said he thinks the video card is loose. Im not sure if thats it though,
    Problem Solver:
  • 12 Answers
This machine has the video card integrated into the main board, so the lose card idea is out the window. However you can check to see if the connection to the display is good by removing the button panel near the display. To remove the button panel:
1) Open the screen until you hit the stops.
2) Gently pull upwards on the right side of the panel above the keyboard.
3) Continue to pull from right to left.
Check the connector on the left side of the notebook. If that is secure then reinstall the panel and check for video output by connecting an external monitor to the connector on the back of the notebook. If you have signal your display is the likely culprit, if you don't the main board is likely the culprit. Either check online for replacements for either of these components, or send it in to Acer for maintenance.
Posted on Nov 11, 2008
No video, white scrren only.
Test computer on another monitor to eliminate graphics card problem
If it works ok, suspect graphics card failing
If it does not, check connections between card and monitor
If tight, assume an internal fault in the monitor, needs repair or replacement
Jan 14, 2011 | Acer Aspire E360 PC Desktop
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Nov 04, 2009 | Acer Aspire m5640 PC Desktop
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Sep 19, 2009 | Acer Aspire 5100 Notebook
Update: Acer Aspire 5100 black screen post by daddysangelg.
yes, check first the inverter, then vga cable connection, or the video card...
Jun 07, 2009 | Acer Aspire 5100 Notebook
Acer laptop monitor black
if you dont have signal on your laptop screen, could be:
Broken LCD, Bad inverter, or bad graphics card.
Sep 23, 2008 | Acer Aspire 5100 Notebook
Black screen but will power up
try outputing to an external monitor.. thats the best way to see if you lcd is burnt out if it does output.. but if it doesn't it mite be you graphic card or driver.. but try that and see wat happens..
Good luck
Jan 06, 2008 | Acer Aspire 5100 Notebook
Black Screen after sitting for awhile
Might be that the graphics card is overheating.
Nov 08, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
