Question about Poulan Garden
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
How do you remove and replace the sprocket/drum/bearing on a Poulan Wildthing 18" 2375 chainsaw.
Thanks,
    Sniper:
  • 52 Answers
Mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Posted on Nov 08, 2008
How do i unlock brake on a Poulan wildthing 2375 chainsaw
First, stop your engine. Check to make sure that the chain brake isn't engaged. The chain brake can activate automatically by a sudden movement or impact. You can disengage the chain brake by pulling the chain brake hand guard back against the front handle and releasing slowly. If the chain brake is disengaged and the chain does not turn; turn off the saw, then check the drive links on the chain, the bar groove and the sprocket nose on the bar. A burr on the drive links will bind the chain in the bar. If the bar has been pinched, the chain will not pass freely through the groove. If a sliver of wood has gotten into the sprocket nose, it will not turn at all. Also, look at the drive sprocket on the saw itself to see if it has a groove worn into it. A drive sprocket with a groove worn into it will damage the chain.
Sep 12, 2016 | Poulan 2375 Wildthing Chainsaw Gas / Fuel...
Poulan 18" wildthing chainsaw (model
This could be a couple of things, if the fuel tank brather is blocke the tank will vacume, to test this try slackening off the fuel cap when the saw starts to die, if it picks up again it is a fuel tank braether issue, the other possibility is a bad ignition unit breaking down, the only test for this is to replace the unit and try again.
Sep 19, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do i remove the piston shaft on a poulan wildthing
Take it to an engine reconditioner as its a specialised job, whether you are removing the conrod or gudgeon pin requires specialist.
Jan 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Runs to fast
You need to adjust the idle and high speed screw settings on the saw. Consult your user manual for tuning the engine.
Feb 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Compression Poulan chainsaw
you can not set the compression on two cycle motors,the compression new is at about 90 to 95 pounds after six to nine pulls of the recoil
Jan 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wildthing 18
Hi tchild, my name is Dennis and I will try to assist you with your problem.
You can get the part from Poulan parts and it will take about 15 minutes to fix the first time eight minutes the second time. In addition I might add that to remove the centrifugal clutch and the sprocket, it unscrews from the crankshaft with a left hand thread. A little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance. Please rate the solution because I can learn from your rating. Thank you
Nov 08, 2008 | Garden
Poulan wildthing chainsaw
Go on the internet to:
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/poulan_gas_chainsaw_product_list_3.html
this is a free site that will give you access to a manual.
Pleased to be of service.
Oct 19, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
1,683 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
