Question about Olympus WS-100 Digital Voice Recorder
Plzz how to format a olympus ws-100
    President:
  • 919 Answers
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Posted on Dec 16, 2008
3 Suggested Answers
SOURCE: Olympus WS-100
I have the same problem is there a solution? In addition I have no power on the handheld and have tried 3 batteries. Any ideas?
Posted on Aug 09, 2008
  • 479 Answers
if you were able to format the recorder thru the recorder.. it should be ready.. but if formatted through the computer, the files needed to operate the recorder are lost and you will need to send to repair to get the files put back on there
Posted on Sep 03, 2008
Can't erase on my olympus WS-100
Do you plug into your computer? If so, you can erase from there.
Does your recorder have a "format" setting? That will erase entire contents.
May 26, 2015 | Olympus WS-100 Digital Voice Recorder
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Feb 04, 2010 | Olympus WS-100 Digital Voice Recorder
Formated the Olympus ws-100 voice recorder via PC and now I cannot use it. What do I need to do to restore it?
Did you have a firmware cd with it? Basically you have lost the software which runs it so need to reload it. I would contact the manufacturer and see if they can send you the software and tell you how to load it.
Jun 13, 2009 | Olympus WS-100 Digital Voice Recorder
Can you save file in WAV format?
The recorder will record the file in WMA format. You will probably need to search for third party software that will allow you to change the format from WMA to WAV. Do a google search for audio editing software that converts from WMA to WAV. Olympus does not provide any software that does this type of conversion.
Jan 22, 2009 | Olympus WS-100 Digital Voice Recorder
Restoring disk on olympus ws 100
I reformat my olympus ws 100 on a mac and, erase everything, and the computer didnt want to recognized it. When turn on the display showed check and went off. When turn on without connecting to the computer and without the hold the display showed no format. If you use the foward button you can change the display to yes format and press play to select. That solve the problem.
Jan 05, 2009 | Olympus WS-100 Digital Voice Recorder
"No Format"
some of the dat files may have been deleted... try to retrieve those files. also formatting the recorder will clear the recorder of all files so you can start out new
Sep 26, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100
Sep 02, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100
Jul 22, 2008 | Olympus WS-100 Digital Voice Recorder
Ws-100
if you formatted the recorder from the computer, all the internal files on the recorder and the recorder will not work
Jun 20, 2008 | Olympus WS-100 Digital Voice Recorder
"full" message
I had the same problem; see earlier post about record times. The "format" solution worked for me.
Dec 19, 2007 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
225 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
