Computer Memory Help!
I have a Dell Dimension e521,Athlon 64x2 3800MHZ cpu, with a Nvidia Nforce 430 chipset,4 slots, 4GB max; I'd like to buy memory but I'm uncertain whether Corsair "xms2 2GB (2x1GB) 240 pin-DDR2 800 (pc2 6400) dual channel desktop memory kit" will work. Please see: http://www.newegg.com/Product/Product.aspx?Item=N82E16820145177&nm_mc=EMC-IGNEFL110608&cm_mmc=EMC-IGNEFL110608-_-Memory-_-L5C-_-20145177
I don't want to spend the money without a second opinion. I've received a lot of conflicting advice.
Thank You.
  • 905 Answers
I would not do it since your computer is recomended for pc 4200(533) and that chip set is recomended for pc6400(800) this matters for the life of the other components not to mention that your computer won't post and could cause dammage, even though your board supports dual channel ddr2 , and I think you should get some memory that is not going to wear your computer down so that you end up having to worry about other repairs also , stay within the recomended speed , so no i wouldn't use those chips in there , and i wouldn't advise someone to do that , but i can see the deal you were looking at!
Posted on Nov 08, 2008
Cpu
AsRock Support > AlivenF6G-DVI Motherboard > Main Support page,
http://www.asrock.com/MB/overview.asp?Model=ALiveNF6G-DVI
In the list on the left hand side, click on CPU Support List
http://www.asrock.com/mb/overview.asp?cat=CPU&Model=ALiveNF6G-DVI
The AMD Athlon 64 X2 5800+ CPU, (Processor), is part number ADA5800IAA5DO.
Operates Up To a maximum frequency rate ('Speed'), of 3.0GigaHertz, has two L2 cache's of 512MegaByte, and uses the Socket AM2 CPU socket.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Brisbane.22_.28energy-efficient_65W.2C_G1_.26_G2.2C_65_nm.29
In the CPU Support :List it is not shown.
This is ONLY because the Athlon 64 X2 5800+, came out way after the CPU Support List was compiled. NOT because it isn't supported.
No, I have to amend that,
http://forums.amd.com/forum/messageview.cfm?catid=14&threadid=108319
It's because AMD's lack of information, apparently, that AsRock didn't list it.
I don't see the voltage range listed anywhere. (To include AMD)
http://www.cpu-world.com/CPUs/K8/AMD-Athlon%20X2%205800+%20-%20ADA5800IAA5DO.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103274
At any rate let's go with deductive reasoning, and see if this CPU is supported.
1) You can compare the Athlon 64 X2 5800+, to the other CPU's in the CPU Support List; that are comparable to it, and above it.
Don't even have to go too far.
Look at the ADA6000IAA6CZ, and the ADX6000IAA6CZ CPU's.
The two Athlon 64 X2 6000+ versions.
(Doesn't state that, just the above part numbers)
However I DO notice that the ADX requires BIOS version P2.00, and the ADA only requires BIOS version P1.60
(Since BIOS)
2) The motherboard chipset is an Nvidia GeForce 6100 and Nvidia nForce 430, Or Nvidia GeForce 6150SE and Nvidia nForce 430
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#For_AMD_processors
Compatible? Yes.
May need the P2.00 BIOS update, if not already installed.
Regards,
joecoolvette
May 16, 2013 | Asrock Computers & Internet
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
I need help upgrading PLZ URGENT dell dimension E521
The most powerful CPU Dell sole in the E521 was the 5600+, 2.8G, Pretty Cheap on EBay
http://shop.ebay.com/i.html?_nkw=Athlon+5600%2B&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Athlon%2C+5600%2B%2C+2.8G%2C+1MX2%2C+Dual+Core%2C&_osacat=0
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Oct 08, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
I removed the old memory and installed 4 1GB cards and the computer doesn't work? Help.
Adding new memory can be tricky. First the new memory has to be compatible with the motherboard.
By that I mean, you need to know how much memory the motherboard can max out at.Can it take only 2 GB or 4GB etc. And it has to be a match to what memory speed your motherboard can handle. If your motherboard takes DDR than you must put DDR in, if it takes DDR2 than you must put DDR2 in. Look at the old memory, and try to match all the numbers you find on it. Than look up the memory specs for the motherboard to find out how much it can take.
Any computer will not operate corecctly if the memory is the wrong kind, or installed wrong.
Jul 02, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Jun 28, 2009 | Computers & Internet
I own a Dell Inspiron 531S. I'd like to get a new graphics card. I currently have a NVIDIA GeForce 6150SE nForce 430. I don't want to spend too much for this but I'd like to run my Second Life game with...
When you install a new video card you must disable the onboard video card by going into the bios setup. Below I have listed the requirements of Second life game. e 531 does come with PCI-E slots so make sure you buy a VIDEO card with PCI-E Walmart sells some pretty decent priced Graphics cards. pretty much any pci-e card you buy new in walmart these days will be fine for this game.
PC Minimum System Recommendations:
* Internet Connection*: Cable or DSL
* Computer Processor: 1.6GHz Pentium 4 or Athlon 2000+ or better
* Computer Memory: 512MB or better
* Video/Graphics Card**:
o nVidia GeForce FX 5600, GeForce 6600, or better
o OR ATI Radeon 9600, X600, or better
M
Jan 02, 2009 | Computers & Internet
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
