Question about NEC-Mitsubishi Nec Display Solutions DiamondPoint V71LCD 17" Flat Panel LCD Monitor
No screen ( mitsubishi diamont point V71LCD)
At power on monitor the screen is on for 2 two seconds and go off, turn off monitor, turn on screen is on for two seconds
what do i have to repair in monitor??
    New Friend:
  • 62 Answers
1. check the monitor neck board.
2. remove the G2 pf.
3. Solder the drypoints in monitor kit. Yoke connections.
Posted on Nov 08, 2008
Fuse box 1998 mitsubishi diamonte
Couple of places to look, under the dash on both sides or under the hood on both sides.
Sep 19, 2012 | 2001 Mitsubishi Diamante
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
May 09, 2011 | LG 26LH20 LCD TV
Px42XR3A, NEC monitor lost picture of any type after showing a series of color bands from all sources. No other set in the house is affected and the sound through the receiver is just fine.
The picture board on your monitor is bad, since the power or button is on and sound and other things are fine, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | NEC-Mitsubishi Nec Display Solutions...
I just bought a used Mitsubishi-NEC V71LCD monitor. After connecting the power cord, and the video cord, I powered the monitor up. It had a video display for about two seconds, and then went black. I reset...
dhowie, Monitor will need work done to internal "switch-mode-power-supply"/"CCFL inverter supply board. possible bad electrolytic filter capacitors or thermally intermittant component soldering on printed citcuit board. Your CCFL back-lit LCD display no different than any other brand in it's basic design and operation. Spend an hour in my fixya profile reading about black screen and blank n black screen stuff. Then you will know what you will do or not do to solve V71LCD problem. Follow the links to other sites for more info here on fixya and elsewhere. I will check for response from you at this same posting later.
12fixlouie
Mar 11, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
I have a NEC LCD 1760V and the resolution notifier keeps popping up. How do I eliminate this problem. It keeps telling me to exit.
insert the AGP card in the AGP slot in install the drivers the problem will be definatly solved the card should be of 8X grade
Mar 04, 2010 | NEC-Mitsubishi Nec Display Solutions...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
The sreen is black, and the monitor light is orange
This usually indicates an input problem. There are number of things to check:
Make sure the screen is plugged into a working output on the video card - if you can, test the video with a different screen.
Try a different cable; Swap for the same type of cable, or, if available, use a different output method(Such as HDMI).
If using an adapter on the cable, try using a different adapter.
Test the cable on a different display, if possible.
Ultimately, if the video card, cable, and connector are all working, or the display is still not, its likely a bad input board within the display - if you're savvy and have some time to kill, replacement boards cost between 20-70 bucks on ebay.
Feb 10, 2009 | NEC-Mitsubishi Nec Display Solutions...
Resolution notifier v71lcd
go into the on screen menu, select the tools menu and you can turn the resolution notifier off.
Aug 12, 2007 | NEC-Mitsubishi Nec Display Solutions...
DiamondPoint V71LCD Not displaying image
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Jun 27, 2007 | NEC-Mitsubishi Nec Display Solutions...
NEC-Mitsubishi Nec Display Solutions DiamondPoint V71LCD 17" Flat Panel LCD Monitor Logo
225 people viewed this question
Top NEC-Mitsubishi Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
mukhtar21 shaikh
mukhtar21 shaikh
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
