Question about Ricoh Aficio AP206 Laser Printer
Ricoh AP206 Need help on a SC41 code
A while back our printer was fed some paper with staples on them and essentialy wiped out our drum. We finally got enough $$ together to get another one and have installed it. However, upon restarting the machine it turns on but outputs a SC41 code. Anybody know what this means?
We're in Mexico and haven't been able to find anyone yet who can/is willing to work on this thing.
Have a great evening! :)
  • Fred Frazelle
    Fred Frazelle Nov 11, 2008
    A helpful individual on another forum suggested that i check my connections bec. they said that this (SC 41) is a fuser connector error.
    Does anyone know how i should go about "checking my connectors"?
    Have a great day! :)
  • 15 Answers
Im not positive but im pretty sure sc541 is a Fuser code
Posted on Mar 02, 2009
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
How do I change the Window's workgroup on a Ricoh AP206 color printer
The workgroup is a function of your windows OS not the color printer.
Apr 08, 2010 | Ricoh Aficio AP206 Laser Printer
I have an AP206 and the paper feed does not always work and print alignment is skewed
Try denatured alcohol to clean the feed wheels. They sometimes get a coating of toner on them and makes them slip.
Dec 15, 2009 | Ricoh Aficio AP206 Laser Printer
Prints black dots at bottom of page - photoconductor was replaced earlier today
The black dots could be a few things, the most likely would have something to do with the drum area because the dots didn't appear until after service. If the dots are only about an inch apart it is probably the charge roller. If there is only 1-2 dots per page, the issue is likely with the drum. These figures are assuming you are running 8 1/2 x 11 paper with the long edge being fed in first. If this is the case, you can change the paper to feed with the short edge first and this may get you by until the technician gets back out to fix it.
Nov 18, 2009 | Ricoh Aficio 450 Copier
Cannot print a manal with the finished size as 5.5x8.5 folded and stapled. IT SHOUD PICK UP THE 8.5X11 PAPER AND FOLD AND STAPE IT BUT IT DOESN'T. Please HELP.
for the 8.5x11 paper to staple the paper has to loaded in the machine with the short edge of the paper fed first so if the paper is turned the wrong way in the paper tray the machine will reject the fold command it should say on the paper type setting 8.5x11R
Jul 21, 2009 | Konica Minolta Office Equipment & Supplies
Will not staple
Hello sir; Remove the staple cartridge check there have left over used staplers , just dump it out,also need to check vertical lifting motor moving smoothly.
Jun 01, 2009 | Ricoh Aficio 450 Copier
NOISE
My machine had the same problem. A service tech looked at my machine and pulled out the OPC Belt Drum Unit. The drum unit had a few issues: 1) jagged rips in it, something caused by running papers through that had staples or paperclips in them. So when the drum turns, it scrapes other parts and the machine sounds like its going to drop all its nuts and bolts--at least mine did!)! and 2) the spindles from the OPC unit has come loosened and fell off. The spindles and plastic cogs were found way at the bottom of the OPC Drum slot. This too was thought to have added to the rips in the drum.
I replaced the drum ($399 was the cheapest I could find) and the problem went away.
An expensive repair but for me it worked...
Aug 05, 2008 | Ricoh Aficio SP-C210SF Printer
Ricoh printer driver
Julia - i found my original Ricoh Color Laser AP206 CD, Ver. 1.10. Do you still need this?
Warmest greetings, fred
Apr 10, 2008 | Ricoh Aficio AP206 Laser Printer
Flaws at top of each page when printing
Replace toner cartridge drum is scratched
(Possibly by staple going threw machine if that what each of the five marks look like, all those removed staples always seem to end up in printers)
You can pull it out (I think right top cover opens and cartridge pulls up and to the right)  then .. turn it over and gently pull back cover see drum has same marks as you see on paper, you can gently rotate drum by using gear on edge do not force it only turns easy one way, Do not touch drum surface very delicate and sensitive. Normal disposable item buy a New cartridge here is HP part number for your model  HP C8543X (HP 43X) Toner Cart.
Oct 19, 2007 | HP LaserJet 9040n Printer
Ricoh Aficio AP206 Laser Printer Logo
188 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
