Question about Philips 60PP9352 60" Rear Projection Television
Philips rear projection replaced ic's and now picture turns on and off
  • Edward
    Edward May 11, 2010
    Which IC's did you replace? Check your soldering for bridged connections.
Look on the Techlor website. They are suggeting that the color convergence resistors be replaced when the ic's (392-120/150) are replaced if these are discolored. They also recommend using only OEM replacement parts.
Posted on Dec 18, 2008
Philips proejector 55pw938317F is turning on and
Bad STK ICs replace Both of them i 110s up grade to 180s they are big black ics will have part number on them STK392-110 call mats 1-800-628-1118.
Sep 21, 2009 | Philips Magnavox 55P9271 55" Rear...
Power indicator on i hear a click no picture then it turns off
Replace Both of your STK ICs they are big black ICs will have part number on them STK392-110s use 180s.
Aug 06, 2009 | Philips 60P8241 60" Rear Projection...
No picture
Replace BOTH of your STK ICs will have part number on them they are big black ICs.
Feb 18, 2009 | Philips 60PP9202 60" Rear Projection...
Philips rear projection tv
Go back recheck where you solder and connections.
Nov 09, 2008 | Philips 43PP9202 43" Rear Projection...
Philips Rear Projection TV 43PP9202 Picture looks 3D
You need to replace both convergence ICs they are STK392-120 you will also need about four 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures. here is the link.
http://servicemanuals.vstore.ca/
Jul 20, 2008 | Philips 43PP9202 43" Rear Projection...
TV screen problems
convergnce IC are bad replace both of them that should straighten out your problem. But also check th resistors right next to th ICs as 1 or 2 of them may be oen as well
Mar 13, 2008 | Philips 51PP9200D Television
Philips 55P8342 Bow in picture
Replacement IC's suspect...did you use generic ? For all my repairs where originals are STK392-110,120 or 150....I use the
up-grade STK394-160E Mfr by SANYO with Hitachi part number
CZ 01341...they are expensive,but NO RE-CALLS ! Also,did
you check the resistors close to the IC's for over-heat damage ?
...........................................T.
Feb 21, 2008 | Philips 60P8342 60" Rear Projection...
Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Sep 25, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
