Question about SanDisk Sansa View 8GB MP3 Player - Black
Won't turn off
I connected my sandisk view to charge it and then i unhooked the connection from the computer and the sandisk is still showing it is connected and it has been 2 hours now. how do i turn it off or to play
  • 80 Answers
Hold the on button up untill it turns off that always works for mine
Posted on Nov 14, 2008
My mp3 wont charge the screen when its connected to the computer shows the light bolt for a couple of seconds and then the batery just turns red again ive tried everything
You can try and fix it yourself first. Go to the SanDisk support site and look for the "Updater program" run the update on your player before contacting support for a repair.
Oct 08, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Can I use my Sandisk Sansa C240 while it is charging?
This is normal when the Sansa is connected to a computer. You can use it while charging if you connect it to something else. For example, you might have a cell phone with a USB charger that plugs into a wall outlet. You could connect the Sansa to it, and it would let you listen while charging.
May 01, 2010 | SanDisk Sansa c240 MP3 Player
My sansa view will not finish turning on. It stops after sandisk sansa apprears on the screen. How do I fix this?
SOLUTION 1 - Make sure player is fully charged.
1. Connect the player to the PC.
2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, then connect it to the PC.
3. Leave the player connected for approximately 2 hours to charge.
4. Disconnect the player from the PC.
5. Verify if you can turn on the player.
6. Reset the player if necessary.
SOLUTION 2 - Reset the player.
http://www.doremisoft.net/Sansa-articles/Convert-video-to-Sansa-on-mac-osx/
Feb 25, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
When i take off charge
That is normal behavior for the player. The functiosn only work AFTER you've disconnected it from the computer.
-Tha Mp3 Doctor
Oct 27, 2008 | SanDisk Sansa Clip MP3 Player
Charging SanDisk Sansa
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa view mp3 player
Maybe you should clean to ***** *****
Feb 28, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Nothing happens when I click on Menu button
SanDisk Sansa View - Reset - Use the slide switch on the side and hold it tward the Mic hole for 10 sec. Start the computer program before you plug in the View??
Jan 20, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Mp3 won't turn on
These don't charge. They use a battery.
Jul 01, 2007 | Coby MPC-848 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
35 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
