Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki Vulcan Classic 1500
Installed new clutch. Re assembled bike and found I had pinched a wire and shorted out part of the system. Replaced blown fuses and everything works except the starter. Cannot get it to turn over nothing
Put new 30 amp fuse in starter relay but still nothing am I missing a fuse or have I blown the starter?
    Problem Solver:
  • 13 Answers
Was any of the wires cut through?  Just a shot in the dark, but try unplugging and re-plugging the wire connector going into the clutch lever.  If that doesn't work submit more information.
Posted on Jan 03, 2009
1997 vulcan unable to pull in clutch lever
If the lever was fine as you bled it then the problem lies elsewhere, either the slave cylinder is stuck or the push rod mechanism in the clutch itself is assembled wrong.
May 05, 2014 | 1997 kawasaki VN 1500 Vulcan Classic
1996 Kawasaki VN 1500 Vulcan Classic how to adjust the clutch
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to adjust clutch cable Kawasaki Vulcan Forum Vulcan Forums
How can adjust the hydraulic clutch on my 1997 Kawasaki Vulcan http://xn--80azbq.xn--p1ai/failo/Kawasaki_VN1500__87-_99_Service_Manual.pdf
OEM Parts for Kawasaki
1996 Kawasaki Vulcan 1500 Classic Owner Manual
Apr 06, 2014 | 1996 kawasaki VN 1500 Vulcan Classic
2001 Kawasaki VN 1500 Vulcan Classic the clutch slips when cold
Hi, Garydavis525 and the usual suspects are:
1. Clutch controls improperly adjusted.
2. Insufficient clutch spring tension.
3. Friction discs or steel discs are worn or warped past specs.
4. New wet clutch not pre-soaked for 24 hours.
Clutch Slipping Kawasaki Vulcan Forum Vulcan Forums
clutch slipping
Kawasaki VN1500 CLASSIC TOURER Service Manual
2001 Kawasaki Vulcan 1500 Classic Owner Manual
Mar 31, 2013 | 2001 kawasaki VN 1500 Vulcan Classic
2002 Kawasaki VN 1500 Vulcan Classic clutch will not disengage
Hi, Anonymous and the usual suspects are:
1. Clutch not properly adjusted.
2. Clutch plates rusted together.
3. Hydraulic clutch needs bleeding.
4. Faulty clutch slave cylinder.
5. Faulty clutch ramp mechanism.
6. Broken clutch rod
7. Clutch pack loose on the main shaft.
Clutch won disengage fully Kawasaki Vulcan Forum Vulcan Forums
Clutch wont disengage Vulcan Bagger Forums
Kawasaki Vulcan 1500 Classic Fi Service Manual
2002 Kawasaki Vulcan 1500 Classic Owner Manual
Jul 22, 2012 | 2002 kawasaki VN 1500 Vulcan Classic
Rear brake light inop when using foot pedal
posssible switch failure if it has 2 wires short them together and if it has 1 wire touch it on the frame of the bike
Jul 15, 2012 | 1996 kawasaki VN 1500 Vulcan Classic
1996 Kawasaki VN 1500 Vulcan Classic how to replace the clutch
Big Kid Powersports How To Replace Clutch Plates on Twin Motorcycle
http://www.kytwisted.com/forums/index.php/topic/943-1500-vulcan-classic-clutch
Kawasaki VN1500 Service Manual
Jul 02, 2012 | 1996 kawasaki VN 1500 Vulcan Classic
1997 Kawasaki VN 1500 Vulcan Classic clutch slipping
Vulcan 1500 Clutch Slip Kawasaki Vulcan Forum Vulcan Forums Kawasaki vulcan clutch issue
1997 Kawasaki Vulcan 1500 Classic Owner Manual
Mar 11, 2012 | 1997 kawasaki VN 1500 Vulcan Classic
Need radator for kawasaki vn 1500 classic tourer 2001 is the driffter the same radator as the vn 1500 classic plz hellllllllllllp
TO ALL VN1500 OWNERS....This once happen to me,
I went to the garage to start the bike "Nothing ""The first thing is the lights are bright but no turning over,Next you think the solenoid is kaput but the answer was very simple and the fix takes 30 seconds..
Do not take the bike to bits looking for other problems and look at the clutch leaver and you will see some wires going into a plastic shroud going into the switch in the clutch leaver, Make sure this has not popped out if its connection as it some times may do after a few years due to constant turning on the handlebars,
When this is not connected you will have a bike that will not fire up but comes alive and you will hear a clicking noise but this is from the engine carb area and every function of the bike will work but it will not turn over, Worth looking at and saves sixteen quid for a starter unit you never needed.
Feb 06, 2012 | kawasaki VN 1500 Vulcan Classic Tourer Fi...
2004 Kawasaki VN 1500 Vulcan Classic will not idle without choke on
Hi, Jack and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike won Run without Choke
http://www.vn750.com/forum/22-carbs-fuel-system/50473-will-not-idle-without-choke.html
2003 Kawasaki Vulcan 1500 Classic Owner Manual
Oct 16, 2010 | 2004 kawasaki VN 1500 Vulcan Classic
2004 Kawasaki VN 1500 Vulcan Classic clutch is making a whining noise
Hi, Christine766 I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH---WHINE
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK& RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
Whining Noise when clutch ENGAGED Kawasaki Vulcan Forum Vulcan Forums
My 1998 Vulcan 1500 classic What is causing this sound
Jun 23, 2010 | 2004 kawasaki VN 1500 Vulcan Classic
kawasaki Full Suspension Mountain Bike Men Logo
122 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
