Question about Sharp R-1481B Microwave Oven
Microwave door doesn't shut
Hi, My microwave door does not shut. (R-1481) The black latch on the handle is not broken or cracked. All the lights and everything works. I unplugged the microwave I took off the key pad panel to expose the wires. I look to the side where the latch is suppose to latch on but I don't see why it isn't latching on. I'm pretty good at fixing things if I have good instruction. Can anyone please help me? I would like to fix it instead of spending the money to buy a new microwave. Any and all help will be greatly appreciated. Thank you! blessedmom
  • gockenmama Jan 07, 2008
    I have removed the door and found in fact the tabs inside are broken off by the spring. I'm not sure where to go from here. I do not think I can glue them back on. Thank you!
  • Sharp Master
  • 9,156 Answers
I answered this personally via e-mail (and I do not mind peopke writing me personally). I think you may have a broken tab which holds the door latch head spring in place.
Posted on Oct 20, 2006
SOURCE:
DOOR LATCH PROBLEM...HOLDING IT CLOSED AND TURNING IT ON WORKS AND HEATS. IS IT A DIY FIX PROBLEM? THANKS FOR THE HELP, DEBBIE
follow this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2gPqmd5pf
Sep 30, 2013 | Frigidaire FGMV174K Microwave Oven
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Door wont open
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aSkJuabC
Jul 29, 2013 | Haier Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
The door doesn't open
please follow the instruction and fix it. God bless you
May 28, 2013 | Cuisinart Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Mopdel # R-1481 m: door latch doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 19, 2010 | Sharp R-1480 Microwave Oven
Plastic latches on door have no tension. Microwave thinks door is open, because latch is not ingaging. How do I access the latch hardware.
with butter knife or small flat head screw driver, carefully remove the plastic ring from ther inner door .cheap repair is to hook the spring to the metal fins inside the door if not order outer door panel
Jan 19, 2010 | Sharp R-1480 Microwave Oven
Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Sharp R-1481B Microwave Oven Logo
339 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
