Microsoft windows xp
Says reinstall preformance center
  • 19,396 Answers
Go to control panel>>add remove programs, and remove the Performance Center program from there, this should fix the problem.
Alternatively do a system restore to a recent date before you had the problem
Posted on Nov 08, 2008
Reset factory mode
You can uninstall it and reinstall it. There is no "factory mode" in Microsoft Windows XP Media Center Edition 2005 for PC.
Jul 21, 2014 | Microsoft Windows XP Media Center Edition...
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
Nov 13, 2010 | HP Pavilion dv6000z Notebook
Reinstalled windows xp and now my audio doesn't work and is greyed out
your audio is not working because when you reinstalled windows xp that deleted the driver for your audio card. you can go online and look up the drive and download it
Nov 08, 2010 | Microsoft Windows XP Media Center Edition...
Having a problem with my gateway comp. using
  1. Boot to your XP CD, enter Recovery Console and run the command CHKDSK /R and see if that resolves
  2. Run diagnostics on the HDD, it may be failing, replace HDD if diags fail
  3. In-Place (Repair) reinstall of WIndows http://windows.microsoft.com/en-us/windows/help/install-reinstall-uninstall
Jan 25, 2010 | Microsoft Windows XP Media Center Edition...
Media Center for Window XP, TV don't work.
Try reinstall windows. If this doesn't work you might have a conflict with your tv-tuner
Nov 02, 2009 | Microsoft Windows XP Home Edition
Windows xp media center error occurs when trying to record programs
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
The media center is part of the WMC operative system. You can also reinstall media center alone using add remove programs, then Add remove windows components. Often that does not work, and you need to use a Windows MCE setup disk to fix the problem.
Apr 03, 2009 | Microsoft Windows XP Media Center Edition...
Apc preformance center
APC Main , or "Apcmain.exe" is a type of spyware that has infected your computer. It goes by the name of SpywareStriker.
Luckily there is a program out there that will automatically scan and remove the threat for you. You can download that program here: Download
After doing that I would also recommend running your own spyware scan to verify your system is clean , I would recommend the program "AVG" for doing that....
This should get your system clean and running back in tip-top shape.
Nov 06, 2008 | Microsoft Windows XP Media Center Edition...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
