My HP 7600 will not print black ink. I have changed cartriges and cleaned print heads. I have uninstalled the program and reinstalled the program. No luck. Any suggestions?
  • Anonymous Apr 25, 2009
    My HP 7600 will not print in blue, it comes out pink
  • 27 Answers
Hii,
try to change with new cartridge...
Posted on Nov 08, 2008
My printer will not print in black. I put in a new black cartrige after the old one did the same thing so I know its not the cartrige itself. I used the instructions on the printer for it to clean the...
Maybe there is fault in the software and will need a re installation. so remove your printer from the PC and un-install the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Black ink cartridge does not print well, it prints with alternate horizontal black linings.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
please check this link for cleaning the head before confirming it to be changed..
www.youtube.com/watch?v=LGPCjKzRtBk
Sep 25, 2010 | HP DeskJet F4280 All In One Printer InkJet
Printer was off for a week and when turned on indicates "incorrect black cartrige installed"
Use lint free cloth and clean the contacts on cartrige and contacts on printer were the cartrige gos in. Be very gentle and very careful do not damage the contacts. Reinstall the cartrige an try again to get it to print. Do not touch the inkjet on the bottom of the ink cartrige it may distroy the print head chip on the ink cartrige and make it useless.
Sep 16, 2010 | HP PSC 750 All-In-One InkJet Printer
Printer replaced with black cartridge, and doesnt print
Either the print head for black is faulty, or the wiring to the black print head on carriage are broken. Try also cleaning the metal sensor to the black cartridge inside the ink carriage.
Apr 14, 2009 | HP Officejet J5780 All-In-One InkJet...
Cleaning the print head on my HP5440 printer?
Try cleaning the head of the cartrige with alcohol and a Q-tip, if this doesn't help you may have to buy a new one. Cartriges can dry up if they haven't been used for a while. Even though you refilled it, there could be some dry ink stuck in the head. Hold the Qtip with alcohol on the head for a bit and let it dry, reinstall it and then try printing again.
Nov 08, 2007 | HP Deskjet 5440 InkJet Photo Printer
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Will not print black
first of all the most important auestion is have you used compatible ink cartridges or genuine ones, because the print head clogs up with compatible ones, i really doubt that the cartridge you installed is damaged because i haven't come across this and i am a canon technician, i know this model well
Nov 02, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
363 people viewed this question
jasbo
jasbo
