Computers & Internet Logo
Anonymous Posted on Mar 26, 2012
Lost password on hard drive - Computers & Internet
  • Anonymous Mar 26, 2012
    i lost my product key and cant use my hard drive trying to recover my data with out losing it
Brian Sullivan
Level 3:
  • Computers & ... Master 27,725 Answers
  • Posted on Mar 27, 2012
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5664234
Points
79191
When you boot up to the log in screen type in administrator as user to log in if you cant log in
Restart your computer during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if this fails to remove your password
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
start a windows xp system up n safe mode then click on control panel then user accounts then the specified user which is password protected and it allows you to change the password without knowing the original one.
Restart the computer. Repeatedly press the F8 key until the Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys
then press the ENTER key. Choose "Windows XP Home/Professional" depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator"
Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK
Select the "Administrator" user.
Click Change my password. Enter a new password in the corresponding text boxes.
Click OK. Write this password down and store it in a secure place. I do not recommend that a password hint be used.
Close the User Accounts window and restart Windows.
hope this helps you
Hdd password lost need master code
Roger B,
Dell does not put any passwords on hard drives and does not have a master password for the hard drive.
The hard drive is possibly defective and will need to be replaced. If your computer is asking for a hard drive password and you did not add one to it just hit enter.
Thank You,
Dell-Jesse L
tip
Four Most Common Password Reset Solutions for Lenovo ThinkPad
<span> <p><img src="lenovo-thinkpad.jpg" />Lenovo ThinkPad Laptop password reset or recovery solution varies depending on which password you have forgotten. The hassle of<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-lenovo-thinkpad-password.html">Windows password reset</a><span> </span>process will range from simple inconvenience to total valuable data loss. For this, we have collected the most used Lenovo Computer password lost troubles and satisfactory solutions for you.<br /><b>Types of passwords for Lenovo ThinkPad Laptop</b><br />There are four kinds of passwords we will talk about Lenovo ThinkPad computer and the password reset solutions:<br /> <ul> <li>1&gt; Windows logon Password (Administrator, Domain and User account)</li> <li>2&gt; Supervisor Password</li> <li>3&gt; Hard Disk Password (Master and User)</li> <li>4&gt; Power-On Password</li></ul><br /> 1&gt;Windows logon Password for Lenovo ThinkPadWindows logon password for Lenovo ThinkPad is used to keep personal information private and we are always create some administrator or user accounts on Windows 7/Vista/XP PC and also domain admin or AD accounts on Windows Server 2000/2003(R2)/2008(R2). It will be a big besetment when you lost or misplaced the passwords of those accounts. However, with some easily password recovery ways, it is possible to re-access your Windows system with no damage of the data.<br /><b>Reset Lenovo ThinkPad Password with Password Reset Disk</b><br />If you are a cautious user, then you should have created a password reset disk for your Lenovo ThinkPad. So you just need to insert the password reset disk to<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html">reset Lenovo ThinkPad password</a><span> </span>directly.<br /><b>Reset Lenovo ThinkPad Password with Available Windows Administrator Account</b><br />If you can log on as an administrator for your Lenovo ThinkPad with a right password, then you can reset any other passwords of your lost or forgotten Windows logon accounts directly.<br /><b>Reset Lenovo ThinkPad Password with Windows Password Recovery Program</b><br />If you have not created a password reset disk previously, or cannot log on as an administrator with a right password, and for this situation, like me, you still have option to reset lost password for Lenovo ThinkPad PC with third-party software.<span> </span><b>Windows Password Unlocker</b><span> </span>is such a powerful Windows password recovery tool which enables resetting windows 7, Vista, XP, 2000, 2003 and 2008 password as blank with 4 easy steps:<br />1. Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker</a></b><span> </span>from its official site with an available PC<br />2. Burn a bootable CD/DV or USB flash drive<br />3. Reboot your locked Windows computer from CD/DV or USB flash drive<br />4. Reset lost or forgotten Windows password for Lenovo ThinkPad with easy<br /><b>Reinstall Windows OS</b><br />Reinstall Windows operating system for your Lenovo ThinkPad will be the last choose if you can reset Lenovo ThinkPad password successfully with those workable solutions that have mentioned above.<br /> 2&gt; Supervisor Password for Lenovo ThinkPadA Supervisor password protects the system infor stored in the BIOS. The user must input the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to alter the system configuration. If the Supervisor password is lost there is no way to recover it to enter the BIOS configuration.<br /><b>Reset Forgotten Supervisor Password</b><br />A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To get access, you need reset the BIOS password with some solutions like locate the jumpers or solder beads, or just contact the computer manufacturer or motherboard manufacturer for resetting forgotten Supervisor password.<br /> 3&gt; Hard Disk Password for ThinkPad ThinkPadThere are two Hard drive passwords: a user Hard drive password for the user and a master Hard drive password for the system administrator. The administrator can use the master password to get access to the hard drive even if a user has changed the user Hard drive password.<br /><b>Reset Forgotten Hard Drive Password</b><br />If the user's Hard drive password has been forgotten, check whether a master Hard drive password has been set. If it has, it can be used for access to the hard drive. If no master Hard drive password is available, or if the administrator forgets the master Hard drive password, then the hard drive must be replaced. For this instance you just need ask help from your computer manufacturer to reset forgotten HDD password.<br /> 4&gt; Power-On Password for Lenovo ThinkPadAn Lenovo ThinkPad Power-on password protects the system from being powered on by an unauthorized person. When it has been set, a prompt will appear during the system start up, and the Power-on password must be entered before an operating system can be booted.<br /><b>Reset Forgotten Power-on Password</b><br />If the Power-on password is forgotten and the Supervisor password is known, simply go into the ThinkPad BIOS setup utility and reset the Power-on password, otherwise try the following:<br />1.Power off the Lenovo ThinkPad computer<br />2.Remove the battery pack<br />3.Remove the backup battery<br />4. Please power on the computer and wait till the POST ends. If the password prompt does not appear then the Power-on password has been reset.<br />5.Reinstall the backup battery and the battery pack.<br /><b>Note:</b><span> </span>Some ThinkPad systems have the ability to reset the Power-on passwords in the ThinkPad BIOS setup utility if a Supervisor password has been set.<br /></span>
on Apr 19, 2011 • Computers & Internet
Lost password on WD Scorpio Blue WD5000BEVT hdd
Password is for the computer, not the hard drive. Get a Linux LiveCD and reformat the drive.
Lost password secure access
If you have lost your password for Sandisk Secure Access then you are going to need a professional recovery company that can do data recovery on it.
Lost password
Hard drive passwords are difficult to remove.
These WEB sites maybe able to help you.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
1helpful
Transcend JetFlash v30 - TS2GJFV30 usb flash drive lost access to flash drive I don't remember - Lost Password
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
I have lost my password for WD My Book. I just dont remember the password. What should I do to save my datas without any loss?
IF YOU LOST/FORGOT YOUR PASSWORD, YOU WILL HAVE TO ERASE/FORMAT THE DRIVE. THAT'S IT I'M AFRAID,SORRY HOPE THIS HELPS.......JEFFXC GO TO WD AND DOWNLOAD THE PDF USER MANUAL.......ULC
2answers
Forgot my buffalo external hard drive password even with passwd hint still cannot remember it
and can tell you this , just relax when you are prompted for the password , try not to think about it so much it
will come to you , there's not much one can do for a lost password but to remember it .
Lost HDD password. How can I re-open my lap-top?
Hard drive passwords are embedded in the firmware of the drive itself. You need to try to find out what the password was.
There is an article about this at this site.
Greetings, My Toshiba laptop A135-S4677 is locked and the Bios wants the hard drive password which I lost. Is there a solution? Thank you. My email is [email protected]
Grand Canyon Tech
Grand Canyon Tech
