Question about HP Compaq Presario SR2150NX PC Desktop
Configuration error after trying to restore system
Hi i tried to restore my computer to its original factory condition and after it said complete it then said configuration error and that it will not work untill fixed
    Scholar:
  • 70 Answers
What you really need to do is if you have the originals that came with computer all you have to do is run the system restore and let it the cd run. While it completes the restore. Once it completes it will restart and then all you do is take out the cd once the restore completes. That should solve the problem. If not you can personally send the system and I'll receive the system.
Posted on Nov 18, 2011
    Sergeant:
  • 229 Answers
Go into system restore under windows system tools and rest your restore point to one prior to restoring your computer to original factory condition. Then wait until you can determine which configuration error is the problem and then restore to original settings. Good Luck
Posted on Nov 08, 2008
How do i factory reset my computer
Hi Anonymous,
Let me know the issues with the computer then I can check and see what can be done.
Simultaneously, you may want to use the below link to perform a factory reset (assuming the operating system is windows 7):
http://dell.to/1B8to5P
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Mar 11, 2015 | Dell Inspiron M5040 Notebook
Hi my dell studio laptop will not boot up and has bootmgr is missing press ctrl+alt+del to restart but nothing happens
Darren,
After trying the steps in other post you could try a PC Restore.
Dell Factory Image Restore The Dell™ Factory Image Restore tool replaces PC Restore. Access it from the F8 boot menu.
Windows PC RESTORE
hennph, Windows 7 PC Restore
These are the steps in performing Windows 7 PC Restore:
Step 1: Backup important files and data
Step 2: Remove non-essential peripherals
Except for the monitor, keyboard and mouse, remove all external peripherals including scanner, printer, modem or network cables, Personal Digital Assistant (PDA), USB flash drive or other external Hard Drive, any other external devices (e.g. USB-attached devices), remove the computer from the docking station if you are using one.
Step 3: Restore the computer's software to original condition
Turn on the computer.
As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
Press the <Down Arrow> on the keyboard to select "Repair Your Computer" on the Advanced Boot Options menu, and press <Enter>.
Specify the language settings that you want, and click Next.
Log in as a user who has administrative credentials, and click OK.
Click Dell Factory Image Restore.
In the Dell Factory Image Restore window, click Next.
Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
Click Next.
The computer is restored to the default factory configuration.
When the restore operation is completed, click Finish to restart the computer. The software is now installed as it was when the computer was first received.
Step 4: Restore your personal files and data from backups
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 12, 2014 | Dell Studio 17 Laptop
Willnotbootup says file missing statusoxc00000e9
this error can actually be hardware or software related. Things you can try.
**IMPORTANT: Attempt to backup important data if you still can that you may have before you try to fix the issue as it may cause data lost or corruption***
1. Attempt to boot using the last known-good configuration
-Restart the computer, tap F12 as soon as the computer starts until it takes you to the Advanced Options of Windows. Select Last Known-Good Configuration if available and see if your system will boot that way.
2. Attempt to boot in Safe Mode, if it works, try to do a System Restore to an available restore point when the system was working properly
3. Attempt to restore the computer to the original factory configuration or repair/reinstall Windows using your Windows disc. To try to go back to factory configuration if applicable on your system, try to restart the computer and tap F12 while it starts until you get to the Advanced Options screen and look for the option to Repair your computer, then log in with your Administrator Windows User account if prompted and choose the option for the Factory image restore.
If none of the above help , try to see if you can check if for hardware errors including the hard drive. To do so, turn off the computer, then press and hold the FN key on the keyboard. While holding it, press the power button for 1 to 3 seconds to attempt to power it on, release both keys. If successful, this will initiate a diagnostics test which will give report of hardware errors including the hard drive. If the hard drive fails, time to get a new one.
Hope this helps.
Dec 11, 2011 | Dell Inspiron XPS M140 Notebook
Purchased Inspiron Mini 1012 Win 7 Started - was told it was new, but is not. How do I restore it to its original factory settings?
Hi suscarsimba,
Welcome to FixYa! How are you doing?
Please try the following steps:
  • Tuen on your computer, Start tapping the F8 key repeatedly until the Advanced Boot Options menu appears on the screen.
Note:
You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  • Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
  • Specify the language settings that you want, and then click Next.
  • Log in as a user who has administrative credentials, and then click OK.
  • Click Dell Factory Image Restore.
  • In the Dell Factory Image Restore window, click Next.
  • Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
  • Click Next. The computer is restored to the default factory configuration.
  • When the restore operation is completed, click Finish to restart the computer.
Hope it helps. Thank you for using FixYa.
Apr 21, 2011 | Dell Inspiron Mini 1012 Netbook PC
Cant open windows, have got following error code; Oxc0150002 i want to restore factory settings how can i do this?
Hi, Restore the Computer to the Default Factory Configuration
Notice:
When you restore the computer to the default factory configuration, all data on the C drive is deleted. Before performing this procedure, back up personal files. If you do not back up personal files, the data is lost.
  • 1. Restart the computer. To do this, click Start, click the arrow next to the Lock button, and then click Restart.
  • 2. As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
Note:
Good Luck (please don't post in all CAPITAL LETTERS next time)
  • 3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
  • 4. Specify the language settings that you want, and then click Next.
  • 5. Log in as a user who has administrative credentials, and then click OK.
  • 6. Click Dell Factory Image Restore.
  • 7. In the Dell Factory Image Restore window, click Next.
  • 8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
  • 9. Click Next. The computer is restored to the default factory configuration.
  • 10. When the restore operation is completed, click Finish to restart the computer.
Nov 14, 2010 | Dell Inspiron Mini 10 Notebook
I need to do a factory restore on a 1012 mini how? the f8 thing does not seem to work.
you can only do this type of recovery on certain machines --contact manufacturers site for original "specs" etc
Sep 07, 2010 | Dell Inspiron Mini 1012 Netbook PC
How to preform pc restore for windows 7 in dell laptop?
Press the <Down Arrow> on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press <Enter>.
Click Next.
Jun 12, 2010 | Dell Inspiron 1501 Notebook
Computer keeps rebooting at login page. It starts up by saying it has 3 of 3 updates and don't turn off the computer and it then goes to the login page for a split second before it reboots, How do I fix...
Hi, this is a common problem with a vista update, dont know why it does it, just does! When it tries to restart keep pressing the 'F8' button and you should get advanced boot options menu where you can get windows to try and repair itself to an earlier restore point, if the problem persists then I'm afraid you'll be looking at restoring back to original factory settings. Below is an extract from the Dell manual found at
http://book-lab.ru/pdf/DELL-INSPIRON/service_manual_for_DELL_Inspiron_1525.pdf
Restoring the Computer to the Default Factory Configuration
The Dell Factory Image Restore option allows you to restore your hard drive
back to its original factory configuration as when you first ordered it from
Dell. This option appears on Dell computers that were originally pre-installed
with Windows Vista® and does not include computers purchased through
the Express Upgrade promotion or computers that were upgraded to
Windows Vista from another version of Windows.
NOTICE: When you restore the computer to the default factory configuration, all
1 Restart the computer. To do this, click Start → → Restart.
2 As the computer restarts, press <F8> until the Advanced Boot Options
NOTE: You must press the <F8> key before the Windows logo appears on the
screen. If you press <F8> after the Windows logo appears on the screen, the
Advanced Boot Options menu will not appear on the screen. If you do not see
3 Press <Down Arrow> to select Repair Your Computer on the Advanced
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Select the Yes, reformat hard drive and restore system software to factory
condition checkbox.
9 Click Next. The computer is restored to the default factory configuration.
Hope this helps!
Jun 04, 2010 | Dell Inspiron 1525 Notebook
Fatal system error, blue screen of death need my data!
Have you tried doing complete system recovery?
Turn on the system and immediately start Tapping F11 by holding the Ctrl Key.
It will take you to the recovery page wherein you will be able to select the option to restore the computer to original Factory Condition.
Please let me know if it helps or feel free to get back for any further assistance.
Thank you for choosing Fixya
Feb 09, 2010 | Dell Inspiron 1525 Notebook
HP Compaq Presario SR2150NX PC Desktop Logo
372 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
