Question about Canon PIXMA MP150 All-In-One InkJet Printer
Cannon 150 PAPER NOT FEEDING THROUGH LEFT GOING DOWN RIGH HAND SIDE SEEMS TRAPPED MAKING LOTS OF STRANGE SOUNDS DONE CLEAN ROLLERS ETC CLEAN BOTTOM PLATE NO BETTER AND TRIED SCANNING SAYS POSS WARM UP WAITED NOTHING. NOT A BRIGHT BUNNY HERE ...NEED 5 YEAR OLD TYPE INSTRUCTIONS PLSE THANKS JENNY....
  • 421 Answers
Paper jam in cannon lbp3300 printer
Unplug printer and check paper entry feed ,especially the right side,will probably be dirt or a piece of paper stuck in feed roller, use an air duster (aerosol) to blow out dust etc.
Jan 14, 2018 | Office Equipment & Supplies
Paper Shooting Out
Please have a Check on the below mentioned Points and follow the steps:
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
Good Luck!!!!!!
Mar 28, 2013 | Lexmark X4650 All-In-One InkJet Printer
MP150 paper feed not working on left hand side
Check your paper feeding roller, first clean them
Apr 30, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Paper is not being fed from paper holding drawer. sometimes makes clicking sound. Copier does work when single piece of paper is fed through right hand side of machine
It sounds like the feed tire is dirty, OR the feed clutch has sprung. Remove the paper tray On the right side of the copier where you feed the single sheet, you pull down the door. This exposes a fat gray or black feed roller. Take a clean dry towel and dampen it with wd 40. Gently wipe the roller with the cloth turning the roller toward the paper exit direction. Let the WD 40 soak in for ten minutes, replace the paper tray and try to make a copy. If it does, you need a feed roller which will rquire a service cal/take it in. If still no feed the 'clicking' may be a sprung clutch, service call required.
If this helps, please let me know with a vote, thanx
Jan 30, 2011 | Canon PC-980 Color Copier
How do you replace the platenroller guide rollers?
to replace the feed rollers under the platen. 1 - remove the platen by squeezing the black plastic clips at the ends of the platen and pulling the platen straight up. 2 - pull the paper pan out, 3 - push down on the feed roller set and rotate it towards you. replace bad rollers and put things back in reverse order. there is a guide on the rod the feed roller unit sits on, make sure the guide on the feed roller unit goes back in this. there are pins at the right side and left side of the right and left feed roller units. these are for positioning the paper pan in the slotted tabs on the bottom of the paper pan. make sure the gear on the platen goes on the left side, position the clips to center on the frame, then push straight down. make sure both clip are fastened in. the only reason you should be replacing these rollers is if they are splitting apart or falling off due to the pins at the ends of the rollers wearing off (never seen this happen on a WW6) if you are having some sort of other problem, you might ask for a different solution before doing this - its harder than it sounds.
Dec 20, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
The paper is not feeding through. it is getting caught on one side, then jamming
the roller on one side isn't picking the paper while the one on the other side is. Hwnce the uneven pull on the paper force the paper sideways and then jams.
This is usually caused by dust in the interior of the printer so try this:-
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, jam/crumpling results. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front; if you have a blower please use it as well). This, if properly done should do it. Brush especially the rollers etc.
Mar 26, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Paper feed jamming
check the back of printer and see if there is door u can open. Most likely there is a paper jam u cant see.
May 24, 2009 | Canon PIXMA MX310 All-In-One Printer
My printer is feeding more than one page at a time my printer is cannon 3000
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results?
May 23, 2009 | Office Equipment & Supplies
Dell Laser Printer model 1700
Its caused by the rubber on the feeder wheels getting worn. And the fix is easy. Just peel the flat rubber rings off the rollers, flip them inside-out, and put them back on. Now your paper will feed all the way intot he machine. ( you can order replacements the next time)
Other: Dont use alcohol on these rubber parts, it only dries them out and makes it worse, you can wash them in soapy water though.
Use higher grade heavier paper, its a bit more expesnive but wont wear out your printer with jams and dust.
Most folks (including myself) think the rollers are actuated when printing, actually the paper tray causes the rollers to pop down onto the paper stack when you close the tray all the way. you cant see it, its like trying to watch the refrigerator light go off when you close the door! :)
Sep 20, 2008 | Dell 1700n Laser Printer
Printer
mybe u put a lot of paper .try to put just one and place the paper holder to the left side of the paper
Dec 19, 2007 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
211 people viewed this question
old marine
old marine
