Question about Dishwashers
Kenmore 665 dishwasher
All I get is a flashing lock light . Is there a way to reset it? It is not lock. The light is blinking. Even pressing No Heat Dry for 6 seconds
does not work. When it has been open for a couple of minutes it is not blinking. If I press cancel it's starts blinking.
My model is 665.168.19990
I have no HiTemp wash or heated dry button but I have Water Heat and No Heat dry
  • thomaspclout Nov 08, 2008
    how to reset the lock code ?
    Brigadier General:
  • 6,966 Answers
Initially, pls check if you have a "tech sheet" somewhere, most probably behind in the bottom/kick panel. There would be instructions on how to enter diagnostic mode. Thereafter the error code would be displayed and we can work from there on.
The 665 series has been known to have common issues with the electronic controller unit. Additionally, in some instances, it could just be the keypad. Again, the tech sheet would help you sort things out. This page might give you an idea on the keypad.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
  • 728 Answers
Try doing a full reset by unplugging it overnight and plugging it back up. It should work then by resetting the lock code. If that does not work, you may need to get the lock option checked for shorts or malfunctions by a professional.
    Genius:
  • 1,847 Answers
Push the heated/dry button on the dishwasher for 4 seconds and that will unlock the dishwasher. This is just a safety feature that allows you to lock the dishwasher to stop kids from pushing buttons.
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
How to off on kenmore 665 dishwasher mode or reset the panel
Check user manual or call manufacturer. The unit is not timing out.
Mar 08, 2015 | Kenmore Dishwashers
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Dishwasher 665 15777990
It sounds like the child lock is on. Is the light on when the door is closed and nothing is pressed? If so hold the lock button until the light turns off. If you do not have a lock button, try the heated dry button or consult the manual to find out which button toggles the child lock.
Good luck.
Feb 21, 2009 | Kenmore Dishwashers
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
You might try this general reset sequence and see if it solves your problem:
Press these keys in sequence
Hi-Temp wash, heated dry, Hi-temp wash and heated dry
Nov 05, 2007 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwashers Logo
147 people viewed this question
Top Dishwashers Experts
