Question about D-Link DI-824VUP High-Speed 2.4GHz (802.11g) Wireless Router (NTWLDL824VUP)
Can go to bank of amreica page, but can't sign on. telco's modem works fine.
My isp is using pppoa w/ vc/mux. With their modem I can log on just fine, but I don't want to spend a hundred dollars when I already have a modem. I have tried everything I know but need a little help. My wife uploads picts. to one website called piknik. She is unable to do so from home. At work they have the same isp and she has no problem there.
  • rpace4christ Nov 08, 2008
    comtrend ct-5621 adsl2+ router. I have also tried a starbridge lynx 325. Eastex telephone coop. is my isp
  • Jannette Amandy May 11, 2010
    is the modem you're using, a modem/router in one? Who is your Internet service provider?
  • 132 Answers
Does your modem/router allows access to secured sites or https sites? Can you access other secured sites?
Posted on Nov 08, 2008
Unable to connect to internet via router.Computer says signal strength is excellent.diagnostic check highlighted DNS problem.I think VIRGIN (my isp) have recently changed their DNS nos. Virgin (my isp)...
If you're using an ADSL connection the details you need are below.
Settings for an ADSL connection through a telephone line.
Open a web browser and log onto your router.
Find Internet Wan > Connection Type.
Set the Router to use PPPoA, type in your User Name and Password in the spaces provided. If you do not have a Service Name or do not know it, leave the Service Name field blank. After you have typed in your information, click "Apply Changes". After you apply the changes, the Internet Status indicator will read "Connected" if your Router is set up properly.
WAN > Connection Type PPPoA
User Name > (or or whatever)
Password > *******
Retype Password > *******
VPI/VCI > 0 / 38
Encapsulation > VC MUX
MTU > Leave as Default
Find Internet Wan > DNS.
Select Automatic from ISP
(Virginmedia DNS servers are Primary: Secondary:
Find Lan Setup > Lan Settings
Ensure DHCP Server is set to On
If the details entered are correct the router will show connected and the internet lamp will be green.
Do the configuration on a wired connection.
Jun 19, 2010 | NetGear WGR614 54Mbps Wireless Router...
Belkin FSD7632-4 v8 wireless router will not connect to my ISP
It should be ok aslong as it is in sync. Can you tell me what router settings your using for talktalk? It should be PPPoA, Vc Mux, Mtu of 1432, Idle of 0. Ip assigned by isp is yes. Also make sure your username and password is correct.The username is going to be and password is as provided by talktalk. IF your getting stable sync on the belkin the distance and noise levels shouldnt be causing an issue.
Apr 16, 2010 | Belkin (F5D7230-4) Router (587009)
2wire 585 forgot password and need 2 config have no phone number to change password
f you don't know the system password for the twowire it has a factory reset button near the lan ports
* Hold down the reset button on the back for 30+ seconds.
* Upon releasing the reset button, the router resets itself to factory settings.
* Connect a computer to the 2700HG-B and browse to the URL
* Enter a new password, confirm it and enter a password hint at the bottom of the page, in case you forget the password.
* At this stage you might receive a "Page Not Found" error, but the password appears to be set successfully.
* To continue, manually browse to the url
* Home Page (summary)
* Run System Setup Wizard
* Enter key code 5225 2374 WG62 22AS BJ7P (from to set up manual config
-> Next
Choose TIme Zone -> Next
* Enter ISP set up details
* For most UK ISPs this will be
Connection type = PPPoA
VPI = 0
VCI = 38
ATM Encapsulation = VC-Mux
For Be /O2 users only
VPI = 0
VCI = 101
ATM Encapsulation = LLC
Exit Registration when connected to Internet
If this helps you plese rate and vote
Feb 25, 2010 | 2wire 2700HG-B Router (2700HGB)
After configuring network TCP/IP automatic Dns server automatic or preferred and alternate dns as given by isp, setting router to mode router encaps..pppoa (second trial RFC1483) virtual...
this the web site download the user manual from this site what ur configuration go thought it i think you get it and maybe the problem in the pppoa line its working or not just check it
Apr 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Router and Aol server not conected.
With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It will search for your connection, find it and allow you to log on.
Configuratin instructions can be found here
Feb 10, 2009 | NetGear DG834 Router
How do i configure my dlink 302g modem to my new ISP's settings?
Hi Nitangel
Before proceeding with modem installation you need to gather your connection details from your Internet Provider. You will need to know or find out the following information about your new ADSL connection from your Internet Service Provider:
Connection Type:
Bridge RFC1483
Default IP address: (USB
Username: admin
Password: admin
· Username / password (PPP connections only)
· IP address / Subnet Mask / Default Gateway (Bridge connections only)
· DNS IP Addresses (optional)
To set up, log into the modem using your WEB browser: type in the address bar and press Enter.
Enter username 'admin' and
password 'admin' (default setting).
Go to Quick Configuration page.
Set Refresh Rate to "No Refresh".
Select Operation Mode: PPP.
In the Connection Type drop-down menu select PPPoE or PPPoA profile.
Enter username and your password.
Select CHAP under Authentication Type (check with your ISP if not sure).
Select Operation Mode: Bridge. If you do not see "Bridge" options please update your modem's firmware at
Select LLC or VC Mux as suggested by your provider.
Make sure your VPI/VCI is set according to your ISP requirements:
Click on "Save & Reboot" to save settings.
Then give modem a minute or two to reboot and reconnect. Restart your computer and you should be able to access the Internet.
You do not have to run any login client on your computer or router because your modem logs to your ISP automatically.
Hope this information helps if I can help further let me know.
Jun 17, 2008 | Computers & Internet
Thomsom speedtouch router
set your router to Protocol = PPPOA, VPI = 0, VCI = 38 Encapsulation = VC-MUX , your username is usually your phone number followed by or & your password in the password box (these should be on the letter sent by talktalk when you registered.
Feb 09, 2008 | Computers & Internet
Cant connect to the using the router.
usually the ip address of the router is or If you plug it in then go to start then run. If you type in there cmd and press enter on your keyboard it take you to a dos page (black backround with white text) In there type ipconfig and then press enter on your keyboard. The default gateway is the address of your router. If you type that ip address into your address bar when you open your browser it will take you straight to the router page. There you can confgure it. Let me know how it works out.
Nov 12, 2007 | NetGear MR314 802.11b
Computers & Internet Logo
89 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
