Question about Whirlpool Duet GHW9150P Front Load Washer
Unlock Locked door on Whirlpool Front Loader
Stephono1
Did you see my post? Take the 3 screws off of the front panel located right under the door. Put your arm and hand up around where the door locks. Feel for anything that moves to unclock the door. Once you get the door opened, plug your machine back in to elec. Then run your cycle on rinse and spin. You should be fixed right up!!! Good Luck
    Problem Solver:
The F11 Code came up because I put liquid soap in the dispenser. I had NO water to mix with it, so it did detect the soap. It was not my circuit board. But thanx for the less soap advise. If you had read the reason why I had the problem perhaps you would have understood. I've had NO problems since I did my fix. Was just trying to share in case someone else tried to run their washer with the water turned off.
Posted on Nov 15, 2008
  • 63 Answers
Heck pump watch for codes or numbers like 11 munites is code f11 .if this does fix its your ccu board top back for f11 code."less soap plz"
Whirlpool Duet front load washer. Put car mats in to wash. They are too wide and don't let drum spin. Stopped in first few seconds of cycle and error code came up but, door remains locked. How do I open...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet door locked cannot open it
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader and the door wont unlock
The latch may be broken.
Here are the instructions to manually unlock...
(tip courtesy JSRock)
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
Mt front load duet whirlpool is locked full of water
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
You'll need to manually unlock it.
May 26, 2009 | Kenmore Washing Machines
Washer error code is F 11. will not let me reset
There is a small cover on the front bottom of the washer. Remove it and there should be a door release rod that you can pullto unlock
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
After a cycle my door does not open on my LG front loader
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Jan 26, 2009 | Washing Machines
Kenmore 45986 door lock
Jan 25, 2009 | Kenmore 43142 Front Load Washer
Unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
