Not pumping or spin drying - Washing Machines
  • 62 Answers
Need to know manuf, but could be something stuck in pump
Posted on Nov 08, 2008
I did the field service mode test
contact the manufacturer . you are the repairman .
Oct 26, 2015 | Washing Machines
Not drain/no spin
If the machine doesn't pump out, it wont spin. Make sure the machine isn't on a "drip dry" setting. This will stop it from pumping and spinning. Have a look for foreign objects stuck in the pump or hoses.
Sep 17, 2015 | Washing Machines
Spin dry
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email: khansaleemuddin@hotmail.com
Jan 20, 2013 | Haier XQB60-91BF 1.92 cu.ft. Portable...
Noisy squeel when simpson ezeset 550 washer is spin drying
You need to determine if it is the drain pump or not, these can squeal when pumping due to wear inside, if it is not coming from the pump then it could be either the belt or worse case it is the drum seal. It's just a matter of pinpointing the noise
Mar 10, 2012 | Washing Machines
Machine won't spin clothes dry. I've tried the
remove the lower front panel and look to see where the electric pump hooks up to a hose and than the hose to the tub probly have a small article blocking the drain
Aug 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Spin problem
Bit of a dirty job, but tilt the unit back and remove inlet and outlet pipes to the drain pump motor. Look for any type of restriction like lime build up or the like. Is drain pump inlet and outlet clean etc. Finally does drain pump pump properly.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load does not spin dry the clothes
Transmission or solenoid that should pick and put transmission into spin. I bet it's a kenmore or similar.
Mar 08, 2008 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
