GE GSS20IEP Side by Side Refrigerator Logo
Posted on Nov 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer problem Upright freezer accumulates heavy ice over entire interior. It continues to get thicker by the day covering every thing inside with thick ice.
Anonymous
Level 3:
  • Master 341 Answers
  • Posted on Nov 08, 2008
Anonymous
Master
Level 3:
Answers
341
Questions
0
Helped
203749
Points
1163
Check the gasket on door to make sure it seals good all the way around
Wood freezer f17wce bottom ice
There is water accumulation at the bottom under the basket it forms a thick piece of Ice that we have to break in order to remove it every second day what can I do ..
Frigidaire commercial upright freezer
Empty everything into a few boxes, cover them with lots of blankets. If the unit is in an area that has a drain in the floor, then just hose it down with warm water. If it is a moveable unit, hand truck it out side and do the water thing out there.
DO NOT TRY TO PRY ICE OFF ANY TUBES OF ANY KIND. THEY ARE FAIRLY DELICATE AND DO NOT HANDLE BEING TWISTED WELL.
When your done, reload the unit and from now on, do not leave the door open so much, ice will build up much slower. I generally do mine every 3-4 years. I also keep a few one gallon jugs full of water near the freezer and when I take something about the same size out, I replace it with the number of gallon jugs needed to fill that vacancy.
What all that does it, it reduces the amount of MOIST AIR that can rush into the unit when it is opened, and the ice will accumulate much much slower, plus a side benefit is, if you have a power outage, your have a freezer full of product and frozen water. Great for parties. If you do have that power outage, cover the freezer with a ton of blankets and it will stay as hard as a rock for several days. DO NOT OPEN THE DOOR EXCEPT IN A EMERGENCY. PRESERVE YOUR SEALED AIR CHAMBER YOU HAVE CREATED INSIDE OF YOUR REFER/FREEZER.
kindly,
Jim
Jan 10, 2014 • Freezers
When we open the freezer door, there is ice inside on the top of the freezer door and on the top of the inside of the freezer. We clear it off, but it continues to come back. What is the problem and how...
Take a hair dryer heat the gasket then apply light coatof vaseline
Put something heavy on it for a few days if it is chest type.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
[email protected]
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
4helpful
2answers
Water is accumulating inside the bottom of the freezer.
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Ice accumulating inside freezer
the defrost element under that shelf has burnt out or has a loose connector.
I am accumulating ice inside my freezer
It needs to be defrosted. If ice builds up quickly again then start shopping for another freezer as the repair is not worth it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 21, 2008 • Freezers
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
2helpful
2answers
Whirlpool Freezer Model #EV150NXENOO
This one sounds like the defrost timer is not working and you are not getting a defrost cycle every 6-8 hours (or when needed). Another issue could be that air (moisture) is getting in from a leaky door seal, etc. and causing the freeze up. If you have a sealed system problem where the cooling coils are not uniformly frosted up then the defrost thermostat will not "know" there is an ice condition and therefore not go into defrost mode (same issue if the defrost t-stat is bad). After you have ALL the ice out of the unit it would be a good idea to take the interior rear cover off so you can view the coils. Start the freezer back up and watch over the next 1/2 hour or so to see that the entire coil is frosting up uniformly. If it isn't you may have a plugged system, a leak causing low refrigerant, etc. If over time the coils look uniformly frosted up you may have a defective defrost heating element itself (no heat, no defrost sort of thing). The defrost elements can be checked with a multimeter for continuity if you know how to do that sort of thing. It's hard to know a person's ability by these forums or if they can tackle certain test procedures.
Top Refrigerators Experts
vince
Johnny 1000
