I moved this range from one location to another. The oven light now stays on all the time, the oven will not heat. The panel says "door" When I try to turn the light off with the on/off button, it will not go off. I tried to set the clean,just to check things, the oven door would not lock so it would not heat. We had a now outlet installed, could that be a problem?
SOURCE: Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
SOURCE: Oven not heating KitchenAid KERC506HWH3
Need to check and see if you are getting 220 volts to the element or if the element is showing resistance with an ohm meter. Any resistance means it is ok. If you are not getting voltage to the elements and resistance is ok then the control board is bad. Note: Always check outlet for proper voltage first! Never know when a breaker has gone bad. Should have 220 volts from line 1 to line 2 and 110 volts from line 1 or line 2 to ground.
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
SOURCE: Whirlpool Super Capacity 465 Electric Range not heating properly.
The first thing you will need to do is to verify that you have 230 volts at the outlet. Chances are pretty good that the unit popped one of the double pole breakers. Check the breaker and reset it if you find that you only have 120 volts at the outlet. If after finding that you have only 120 volts and you've reset the breaker then the problem would lie with the breaker needing replacement. If however you have full 230 volts available at the outlet then additional troubleshooting would be needed. Hope this helps... Bill
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
I appreciate your inquiry, Sidney!
I see that you are having a difficulty with the preheat indicator on your Frigidaire range constantly staying on. This could be a possible issue with that switch or indicator light. I would recommend seeking help from a certified technician for exchanging or replacing any electrical components. This will prevent any personal injury or future issues with your range. I hope this is helpful information. -Matt
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
heatman101
