Question about Zanussi WJS1397W Front Load Washer / Dryer
Washer cycle completes but clothes don't clean!
Hi, I actually have a Zanussi WDS1183W but it looks pretty similar to this one! Problem: On a darks cycle the machine completes quicker than it should and the clothes come out smelling nice and fresh but have not been cleaned properly. On hot cycles (whites) the machine just gets stuck after the filling with water, if you then turn the knob to the colours position it will complete the cycle but again not remove any stains. I have previously replaced the pump on this machine and it has worked fine for 6 months. The dryer part of the machine works fine, it spins ok and dissoles the tablets. Has anyone heard of a prolem like this? I am fairly handy at DIY so hope to be able to do a home fix job... could you please help me :) Many thanks, Luke
  • Luke Johnson Oct 23, 2006
    bumping this up... any ideas please gurus?
    Champion:
  • 249 Answers
HEATING ELEMENT NOT HEATING, IF IT DOSE NOT HEAT IT CAN,T MOVE ON
Posted on Nov 28, 2007
Hi - My Whirlpool washer appears to not use enough water. Don't get me wrong, I want the machine to use low water (that's why I bought a front loader, model: WFW97HEX). However, when I stop the...
Don't pause the cycle mid cycle. The machine uses the amount of water it needs to clean the amount of clothes that are in the tub. If you pause it after the first 7 or 8 minutes, you're already past the sensing part of the cycle and likely you won't get more water for the additional clothes.
Also, the clothes don't need to be soaking wet or wet enough to wring out. These new HE machines mix the detergent with water and then spray that detergent solution onto your clothes. Then the clothes against clothes rubbing with that solution already coating the clothes is how the machines clean better! It is a very similar process to when you pretreat your clothes with Shout of Spray and Wash. You spray the clothes and then rub the short against itself. Now the Whirlpool machines are doing this for you!
Aug 30, 2011 | Whirlpool WFW97HEX Washer
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I open the door assembly of a zanussi wds1183w so as to access the door handle and replace it?
www.serviceforce.co.uk/pdfs/U01031.pdf
hi above is your manual, below is a how to repair the door.
http://www.washerhelp.co.uk/diy-repair-help_2.html
http://www.zanussi.co.uk/node67.aspx
Manufacturers website above.
Dec 20, 2010 | Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Zanuassi jet system frony loader has a bad smell
hi this is joyce
They sell a product called affresh it cost about $10.00 you put in the machine and run a cycle and this should take care of the smell. if this does not do it then run pure bleach in despenser and run cycle no clothes in washer. this will kill the mold. also never close the door completly on the machine because this holds moisture inside the machine, so leave a crack in door so the machine will dry out some. this should take care of the problem.
thanks
joyce
Feb 05, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
Clothes not clean after complete washing cycle
is it still heating the water? sounds like the element might be shot
Oct 12, 2008 | Zanussi IZ161S Front Load Washer
Not washing clothes
Sounds like you need a new timer.  Sorry.
Oct 14, 2007 | Zanussi IZ161S Front Load Washer
Cycle completes but doesn't clean!
heater element may not be working,not heating water,good luck
Oct 18, 2006 | Zanussi WJS1397W Front Load Washer / Dryer
Zanussi WJS1397W Front Load Washer / Dryer Logo
82 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
