Question about AOpen MX46-533V (91.89U10.061) Motherboard
Windows installs multiple instances of my video card the. the card is nvidia 5900ultra the board is mx46-533v w/onboard video which i cant figure out how to disable
  • 1,314 Answers
If you really want to disable the onboard video, right click on it in the display properties and select disable. However leaving it on really shouldn't be an issue.
Now the reason you are showing multiple instances of your nvidia card is because there is more than one monitor output on the back. You can hook up two monitors to the card and therefore it is showing up as multiple instances in your display properties. Again, this isn't an issue and is nothing to worry about.
Thanks and please take a moment to rate as fixya.
Posted on Nov 08, 2008
Nvidia gfx card problem
It seems that the problem lays on your Ram,not the graphic card.And since the driver of graphics card is capturing some of your ram memory you are experiencing this error.
Mar 07, 2017 | Nvidia Computers & Internet
Installed GEForce NVidia 8400GS graphic card but no video output. Onboard and other video cards will work. The 8400GS will work in other desktops correctly. Any help would be graet!
Assuming that you have installed the drivers for your new board, go into Control Panel, select Device manager and Display Adapters.
Dissable the onboard adapter and enable the NVidia card.
Dec 27, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the video...
No it can not be possible you can use multiple cable two way .it can solve your problem.Some mother board or laptop has duel option. In that devic can any body use two moniter.
Nov 24, 2010 | Intel Computers & Internet
I have a P5GC-MX 1333, I have an nvidia graphics card, but I want to plug a monitor to the nvidia and to the onboard card as well. Once I installed the nvidia graphics card the internal card is not...
Internal video and AGP / PCI Express video cards use the same "pipeline" so you can only use one or the other, not both.
If you need additional video ports, you HAVE to get additional cards / a video card with multiple video ports.
Apr 09, 2010 | ASUS P5LD2-VM Motherboard
Windows does not see the Nvidia G100 video card in the PCI-E slot. Does not even show up in device manager. Tried to install drivers, but the driver installer says that I don't have any compatible hardware...
Do you have another computer to try it out in? It might be that either the card isn't working, the PCI slot is not working, or the card isn't compatible with the motherboard.
Dec 15, 2009 | Computers & Internet
Video out switching between onboard and PCI-E
have you checked your bios settings? check there if you can disable your internall VGA card and only use your NVIDIA GeForce.
When you start your computer start BIOS to press DEL or F2 or F10 or F12, depends on your computer model and manufacture.
Oct 30, 2009 | Nvidia GeForce 7200 Graphic Card
Cant utilize extended monitor function in XP w/ onboard chipset as other VGA out
You cannot use both the onboard video and a separate card at the same time. Are you trying to use multiple monitors? Your video card must support that if you are, and the Radeon 7500 does not mention that it does. If it does, the ATI Catalyst drivers will have the option.
Jun 02, 2009 | ATI RADEON 7500 (64 MB) PCI Graphic Card
Cant boot up compy with new graphics card to reinstall drivers
if you have an older graphic card swap it out with the new or if u have onboard video use it as your video. Once you boot up uninstall the nvidia drivers and turn off pc. Now reinstall the new card and install the drivers from the CD or the new ones from the nvidia site. Dont use the windows device manager.
May 24, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
With ASUS M2N-MX mainboard, ATI Radeon 7000 Series problem.
Your Motherboard has an onboard video chipset made by Nvidia. Nvidia and ATI have a history of not playing nice with each other.
I have 2 possible solutions for you.
1.) Remove the Radeon card and use the Nvidia onboard card (Essentially a Geforce 6100)
2.) Enter the bios (Usually done by hitting <Delete> or <F12> while the computer is booting up) Your Motherboards manual can tell you for certain. Then find the options for onboard video and disable it.
Then boot up the PC, When it say starting Windows press <F8> to bring up the windows boot menu. Select "Start in Safe mode" Once this loads up open the device manager, look under "Display adapters" find the entry for the Nvidia adapter, right click on it and select either "Uninstall" or "Disable this device"
Which you choose depends on your personal preference Whether you like Nvidia or ATI boards better.
If it makes your decision easier a Geforce 6100 is roughly equivalent to a Radeon 8500 in performance.
I hope this helps
Nov 11, 2008 | ASUS M2N-MX Motherboard
AOpen MX46-533V (91.89U10.061) Motherboard Logo
66 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
