Question about Dell Wireless Keyboard Optical Mouse w0147
Ny dell wireless keyboard has stopped working
This is a fairly new dell. The mouse works but the keyboard does not connect. I have done the usual things - replace batteries, reboot etc. Any ideas?
  • 2 more comments
  • Anonymous Nov 18, 2008
    Same problem here. I have looked for the drivers as well, but haven't found them yet. I tried the Resources or Utility CD that came with the computer as Dell suggests, but haven't found any drivers on there for the wireless keyboard/mouse.
    And yes, replaced the batteries, and pressed the little green buttons many times, nothing seems to work.
  • joso47 Nov 27, 2008
    Yes the USB blue light flashing there is no green buttons on keyboard. Laptop recognize mouse but not keyboard all DELL products
  • fichtennadel Dec 04, 2008
    The Mouse works just fine, but....when I try to boot up, and it suddenly is impossible to enter a password, it makes it difficult to suddenly check for drivers!
    I've interrupted the boot-up, and actually used the keyboard to examine, change and save parameters for the BIOS, but after all that keying, when it comes time to enter a password to open my Desktop, there is not a stroke from the keyboard that is recognized! What the hell is going on? Batteries are freshly charged (voltage checked), and there are no obstacles between the keyboard and the wireless receiver. USB ports for the receiver have been changed, to no avail.
  • jandrews1231 Dec 17, 2008
    Mouse works, Keyboard stopped working.
    What is solution?
  • 3 Answers
Not wanting to patronize but asking the dumb questions first: have you pressed the green buttoin on the base of the keyboard AND the one on the receiver? Are your drivers up to date?
Posted on Nov 08, 2008
Friggin thing just stopped working no warning what now
try change the batterys conect first the mouse and then put batterys in the keyboard and all shoud work fine again if not working then contact your seller or manufacture company
good luck i just done my one today after 8 month and now all work just fine
Jun 09, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My dell wireless keyboard just stopped working. I
if your mouse is working. it would be the keyboard it self.. cause dell has bout wireless mouse and keyboard.. do you have warrenty on your system.. dell can replace the keyboard for free..
Dec 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My Dell wireless keyboard has stopped working. The optical mouse is still working, but the keystrokes are not being transmitted from the keyboard. I have already replaced the batteries and checked the...
Underneath the keyboard is a little 're-set' button. When you push this it re-synchs with the wireless antenna. Make sure you hold it down long enough fo rthe keyboard to synch, usually about 5 - 7 seconds.
Dec 19, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Hello-I just purchased a Verbatim wireless keyboard and mouse. They are working fairly well except that the keyboard loses the wireless signal on reboot and I have to reestablish the wireless connection.I...
Move the wireless adapter (one end connects to the keyboard/mouse ports on your computer) closer to the front of your computer, i.e., closer to where your wireless KB/mouse are located.
Sep 14, 2009 | Verbatim Keyboard, Mouse, Keyboard and...
My wireless dell mouse isnt working I changed the batteries and still the cursor isnt moving?
there is usually some sort of connect button on both the mouse and then receiver unit that is plugged into the computer, sometimes you have to hold down the connect buttons on each unit simultaneously so that they will connect, i dont know if you have done this or not, otherwise it is always possible that you have a bad mouse, if this is one of those usb wireless mice try moving the usb receiver to a different port and let windows reinitialize it
Feb 20, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless mouse and keyboard not working
Well, you will need at least another keyboard to get going, or else I,m afraid nothing can be done. See if you can borrow a k/b from a friend preferably a mouse as well.
Apart from that you can try the usual..use new batteries in both k/b and mouse, press connect button on reciever and connect button on k/b, wait about 20-30mins and connect the mouse the same way..
Better try to download and install the latest driver from the manufacturer's website first..
Hope this helps..
Apr 18, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Wireless keyboard is blinking a blue light but nothing else is working
Normally Dell keyboard require a wireless uSB plug in that connects to your computer and there is usually a small button on both the keyboard and the end of the connector. Press them both. Normally preplacing batteries causes the connection to be disrupted.
Mar 14, 2008 | Dell Wireless Keyboard Optical Mouse w0147
CANT GET WIRELESS MOUSE TO WORK
Try changing with a new set of batteries. also try to reset the connection of the wireless mouse and keyboard. you can locate a connect button on both the reciever and wireless keyboard. press both of them together and release them. this would reset the connection. try doing the same for reciever and wireless mouse connect buttons. this should work. also check for any possible alignment issues.
Jan 15, 2008 | Computers & Internet
Dell Wireless Keyboard Optical Mouse w0147 Logo
115 people viewed this question
Alun Cox
