Rank: Apprentice
Rating: 100%, 5 votes
I had bought a second battery for my
HP dv6000 after it had got to 0% not charging and a new battery did the same thing in a couple months.
Yesterday, I noticed I had got up to 1% not charging and found that it was shutting down PC with AC cord in and battery in, take out battery, put it back in. Did it 2 times and second time charge light came on steady and it charged. Seems like when powered down, the charger has a chance of working when putting a battery back in with the power connected as it takes a number of seconds to react with the charger light. Taking battery in and out when powered on doesn't seem to help.
Wonder if it letting it get down to 0% that causes the trouble? Also as a precaution, I remove the baterry after I power it down.
But I see some of you have gotten stuck at other power levels, so trying powering it down with AC adapater and battery in, remove battery and then put in back in, see if charge light will come on steady.
The Hp battery check is junk always recommending to "calibrate" the battery. Also tried re-installing ACPI Compliant Control Method Battery, no change.
3 Cheers for trial and error! HP
laptops have problems with their charger systems!
