Question about HP PSC 1600 InkJet Printer
Hp psc 1600 series
The printer says printing and it is not doing anything. I press cancel it won't do anything. I uninstalled the software then reinstalled it again and the printer is not working the usb cord is connected. Before all this happened it was working fine until one of my family members to print and no document came out. help please
  • 1 more comment
  • tands05 Nov 08, 2008
    tried that too nothing happening just says printing
  • Anonymous Nov 13, 2008
    Error: 0x88076f88 1:\Ojfhx\O ba This error keeps showing up on my 1610 HP Printer. Document s are in the print q. but does not print. You can delete the document but the error still remains. I have to unplug the machine to get the error to leave. HELP.
  • jpeloso Dec 11, 2008
    printer says printer but then when you look at the printer on your pc the status says offline and nothing prints.
    Master:
  • 638 Answers
Try to give test page from the printer.without using your computer to print, that will help you to locate where the problem is. in the printer or in your pc settings. thanks.
Posted on Nov 08, 2008
Ksdklhcflk
Posted on Nov 11, 2008
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Can't cancel a HP PSC 750 Printer print job.
Right click on MyComputer and click Manage. Then go to Services and Applications and then Services. Find the Print Spooler services in the list and right click to stop it. When it is stopped try to cancel the document again. Then start the print spooler service again.
Regards,
nicolasiac
Feb 12, 2010 | HP PSC 750 All-In-One InkJet Printer
I have deleted my hp psc 1315 printer, my Compaq
go to hp's website and download the software for your printer it's really easy and doesn't cost anything.
Mar 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP Printer Conflict
Perform a clean and "No bloated" installation of the hardware.
Uninstall ALL the HP printer software, disconnect the PSC and reboot the computer.
When windows finish to load, connect the PSC again, the new hardware wizard will show up, follow the instructions with the HP Installation disk in the drive.
IMPORTANT: When a silver sand glass show up in the screen, CANCEL the installation of the HP software (this is by clicking "CANCEL" button or by no accepting the license terms). This will install only the PSC Drivers and nothing else.
Try printing again.
Feb 15, 2008 | Computers & Internet
Hp psc 1350 printer
i cannot re-install my hp 1350 all in one scanner. i have uninstall and re-install the printer driver was unknown. how can that be possible even i dont have the cd that comes with it.
Feb 02, 2008 | HP PSC 1350 All-In-One Thermal Printer
Scanner Problem
Use a TWAIN compatible program (Windows imaging, photoshop, paint shop pro) and try scanning again.
Jan 27, 2008 | HP PSC 1510 All-In-One InkJet Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
      5. Press Copies .
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Hp psc 1410v
Could be a number of things. I would try looking in printer settings first. Click on your printer, go to properties and check all settings, it may be set to do this or similar. If no go, try uninstalling and reinstalling it, or just turning it off and unplugging, replugging and turn on again can often reset irregulariites. Also try resetting default printer settings too.
Apr 07, 2007 | HP PSC 1410v All-in-One Printer
HP PSC 1600 InkJet Printer Logo
169 people viewed this question
Ben Johnson
