Question about Samsung HP-R5072 50 in. Plasma HDTV
Little red dots
My screen 106 cm 7month old samsung plasma has just recently started getting little red dots every were dark in the picture after it has been on for a couple of hours 9 (Really Anoying). Does anyone now wat causes this prob? or if the tv is just a lemon? Any help would be greatly appreciated, Thanks
  • Fiona Blake Nov 08, 2006
    Spot on this guy is the real deal!!!! Screen went in for repairs under Warranty and two driver boards were replaced, Thanks heaps dude u really know your stuff and probably saved me a packet
    President:
  • 3,130 Answers
The driver board is going bad it sounds like and if you do not call up and get it fixed under warranty, as it should still be under a warranty, then its going to be a nice hefty repair bill. Good Luck Ps Please dont forget to rate this thread
Posted on Oct 19, 2006
Call Samsung customer support. I had the same problem and a Samsung Field Engineer came out to my house and adjusted the vscan voltage to get the red dots out of the Gray/Darker colors. This is a typical adjustment for some plasma's and was painless from my perspective. Most of the time for this fix was taking all the screws from the back panel off and on to get to the adjustment. This was all covered under warranty (including labor). Samsung has a great warranty for their plasma's..
Posted on Dec 29, 2006
SOURCE:
3 year old Panasonic VIERA TC-P54VT25 screen has a series of horizontal red dots from left edge to middle of screen in lower half of screen. Visible when the picture is dark. Not so visible when the
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 23, 2014 | Panasonic Televison & Video
How to fix plasma tv issues?
If you are using an HDMI cable, be sure that is rated a "high-speed". Lower quality cables cannot handle the bandwidth and can cause red spots on the screen.
Aug 21, 2014 | Televison & Video
Red dots on Samsung 51 inch plasma
Usually either the main board or the power board--if set is 6 months old---no warranty?
Mar 18, 2012 | Televison & Video
Hello, why does my plasma tv have thousands of red and green flashing dots all over the dark parts of screen after it has been on for roughly half an hour? if i turn tv off for a while then turn back on...
I had a similar problem but mine was just red specks that showed up in dark scenes. I opened up my plasma and found the adjustment pots that are labeled Vsc, Vy. I then marked the factory default with a sharpie first. Then I lowered the Vy a little and my red specks disappeared. Now my tv looks awsome again like it was new.
May 10, 2010 | Samsung DLP HL-P5663W 56" TV
Red dots all over screen poor picture more when
This is a "mal-discharge" fault & will need either an adjustment on the Y-Sustain board or a software update to the control board. Contact your LG dealer to arrange someone to sort this out for you.
Oct 26, 2009 | LG 42PC3D 42 in. Plasma Television
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
Little dots all over the screen
Sounds like something might be heating up
you could get a can of freeze from radio shack and spay it on the ic's one at a time till the problem goes away to locate the bad part.
Oct 13, 2007 | Philips 60PP9202 60" Rear Projection...
Samsung HP-R5072 50 in. Plasma HDTV Logo
1,046 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
