Question about Famous Brand FP7317 17" LCD Monitor
Monitor display Problem
I got the Monitor from a friend and when i got it home i plugged it in and it didnt display anything. Then i tried turning it off and noticed that it wasnt a normal bright yellow or green light but instead it was a dim, green and yellow flashing (quickly). I unplugge dit and plugged it back in and it shows a normal yellow light for a few seconds then goes back to the flashing. I dont know what the problem is... any help?
Gateway all in one touch screen model zx4931 turns on then shuts off before monitor can boot on.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 25, 2014 | Computers & Internet
My sa200 will not turn back on
Good luck.
Jul 22, 2014 | Samsung SyncMaster SA200 Series 19in LED...
How do i factory reset my NEC LCD1712 Monitor?
Good luck.
Jul 22, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
Why has my monitor turned orange. model dylm19r6 computer monitor
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Jul 14, 2014 | Soyo Computers & Internet
Monitor will not turn on and power light blinks blue
Good luck.
Jul 10, 2014 | Sylvania Scm2401 Curtis Lcd Monitor 24"...
Blinking on/off light.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 06, 2014 | ViewSonic VA1913w Monitor
Lcd acer al1917w display blang white
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Apr 05, 2014 | Acer Ferrari Computers & Internet
Monitor will not turn on after extended periods
Aug 16, 2013 | ViewSonic Computers & Internet
Problems with vga
Either the monitor or the Video Card is bad. To isolate the problem try another monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and plug it into the computer. If the borrowed monitor displays and does ok, then your original monitor is bad. If the borrowed monitor does not display anything like your original monitor then the video card inside the computer is bad.
May 11, 2012 | Computers & Internet
I just got a computer and it worked when we were packing it up. Before we put the computer up my friend wanted to see if he could put a newer video card into it. Well it didn't fit so he put the old one...
he didnt push the card all the way down simple open it back up pull card out and "you" push the card back into slot
the bar on should be flush with case
i hope your friend didnt put it on something that had electrical charge that staticed the card to death
but more than likely he didnt push the card down all the way make sure monitor cable is tight and flush with card in back of comp
if you still dont get picture try another monitor you could have damaged something in monitor in your move
Dec 06, 2008 | Nvidia GeForce 6200 AGP Graphic Card
Famous Brand FP7317 17" LCD Monitor Logo
Top Famous Brand Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Famous Brand Computer and Internet Expert? Answer questions, earn points and help others
