Question about Cameras
I do not know how to delete Protected pictures from my Easy Share Z710 camera
You have to go inand unlock the pictures in your picture menu
Posted on Nov 08, 2008
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
It tells me I have a driver problem
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
May 15, 2014 | Kodak EasyShare Z710 Digital Camera
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or unlocked.man-3ds-sdcardlockswitch-287-181.png
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
I just deleted 12 picures from an easy share album by mistake. how can i retrieve them
Problem Description: Pictures from an easy share album deleted by mistake. It?ll be fine. All your original pictures are on the C drive. Unless you have changed the directory onto which you save when transferring: You can find the pictures under C-Drive, my pictures. When successful please give me the feedback as a rating or recommendation. Thank You
Dec 17, 2009 | Kodak EasyShare C330 Digital Camera
I cannot take new pictures after inserting a new memory card.
HAVE YOU TRYED PUTTING THE PICTURES ON YOUR COMPUTER SO YOU DONT LOOSE THEM BUT THEN YOU'LL ABLE TO DELETE THEM OFF YOUR CAMERA ? TO RELEASE THE INTERNAL MEMORY YOU'LL HAVE TO DELETE THE PICTURES MOST CAMERAS HAVE LIMITED MEMORY AND IF USEING A SETTING LIKE HD PICTURES WILL USE UP ALOT OF THE MEMORY TRY SETTING YOUR CAMERA TO TAKE PICTURES IN A SMALLER FORMAT LIKE VGA OR A SMALLER RESOLUTION
Mar 30, 2009 | Kodak EasyShare Z710 Digital Camera
I have a Kodak easy share # Z710 and I can't all of a sudden can't delete the pictures on the memory card. My camera says that the memory card requires formatting. Can you explain to me just how to do...
Go to the "Set up" portion of the Menu, choose "Format." Note this will erase all the data on your memory card, so you want to download the photos someplace first.
Sep 28, 2008 | Cameras
Cameras Logo
255 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
