Question about GE WDSR2080D Top Load Washer
Washer will nor drain or spin.
Hello, My washer will not drain or spin, however it does aggitate. Please help.
    Problem Solver:
  • 5 Answers
Check for a bad lid switch
Posted on Aug 16, 2007
    President:
  • 878 Answers
Lil, start by checking the drain pump. Remove the front panel by pushing in on the clips on the left and right side just below the top. The panel will pull toward you. You will see the pump on the right. Start the washer in spin and with a meter see if you have 120V to the drain pump. If you do and its not draining, you have a bad pump. Part number for the pump is WH23X10013. Catriver..post back.
Posted on Oct 19, 2006
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
I have a GE washer (WBB4500G2WW) - wont aggitate or spin
The BELT... Part number wh01x10302
30% of the time is the issue here:
http://www.appliancepartspros.com/ge-belt-wh01x10302-ap3968432.html
Have a look at appliance-parts-pros (video guide)
http://www.appliancepartspros.com/repair-help/general-electric-washer-wbb4500g2ww-repair/wbb4500g2ww-pumps-but-will-not-spin.html
May require a specialty tool to mount the belt
(depicted in VIDEO... Sold on site): view here:
http://www.appliancepartspros.com/ge-service-kit-belt-wx05x20641-ap5957260.html
((not entirely convinced the tool is critical but the
Also check prices on eBay (top seller, free shipping
WH01X10302 AP3968432 1264395 PS1482278 WH01X10353 Washer Drive Belt eBay
Hope this holds off trashing your three year old washer...
Carnac the Magnificent
Jan 15, 2018 | Whirlpool Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
My washer machine is not draining, nor spinning, i replaced the timer, lid switch, and the pump, and its still not draining or spinning. it aggitates so theres nothing wrong with the motor, i dont know...
Hello Friend,
your machine is neither Pumping nor spinning, that is why it is unable to drain the water out. In this case you should check the pump. Your washer probably has a frozen pump pulley. If so you need to replace it. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Do get back to us if you need any further assistance.
Thanks
Mar 05, 2010 | Whirlpool LSR7333 Top Load Washer
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Kenmore 20722
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
GE WDSR2080D Top Load Washer Logo
69 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
