Legend MP3 player stuck on single-song loop
Hello, I haven't got a manual to help me. When I press play, the player is stuck looping one track. I don't know how it got like this! There is a small 1 in the middle at the top of the screen. No button or combination of buttons will remove it. Thanks. Nicola.
Hold down the EQ button to step through Loop, 1 or ALL.
Posted on Sep 26, 2009
Gpx MW249s wont play help
I had the same problem with my GPX mp3 MW249S. I went to the internet and downloaded MP3 Repair Tool 1.5.2 software from www.free-codecs.com and l managed to fix the problem.
Feb 23, 2010 | GPX MW249 MP3 Player
I have over 500 songs on my MP3. Only thirty songs will play.
you will have to get a new 1 cause the same thing just happend to me
Nov 02, 2009 | Audio Players & Recorders
Loop points are not accurate
you can not use a third party program to convert to mp, it won't loop right, use the windows media player to convert to mp
Sep 13, 2009 | Tascam MP-GT1 MP3 Player
I have a Durabrand C.D. player I bought from Walmart and lost the instructions to it. Where do I find the instructions. I have a c.d. with 4 tracks on it and want it to repeat track #3 when it gets to...
HELLO,DO YOU HAVE A PART # FOR YOUR CD PLAYER ? TO GET A USER MANUAL I'LL NEED IT.ALSO IS IT A WALKMAN OR A CLOCK RADIO ? ECT WHAT TYPE OF CD PLAYER IS IT ? MOST HAVE A REPEAT OPTION OR BUTTON YOU CAN PUSH TO REPEAT THAT SONG IF IT DOES HAVE THE REPEAT OPTION THEN JUST HIT IT WHEN THE CD PLAYER GETS TO THAT SONG TO REPEAT IT OVER AND OVER OR LOOP IT THEN TO TAKE IT OFF AND PLAY NORMAL HIT IT AGAIN
Apr 05, 2009 | Audio Players & Recorders
GENERAL QUESTION
I believe what Tascam means by the 'effect loop' on the 2488Mk2 is simply a send loop within the device which internal effects can be set on (vs. a the 'send loop' which exists when you send a track out the sends, through an external effect device, and then back through one the the 2488 inputs). This effect loop is sent to the stereo bus as well as the bounce sub mix.
To use the internal effects in this way you'd select a track with the 'select' button for the track (or you can do multiple tracks by repeating this process for each track one at a time). Then press the send button and on the top of the screen you'll see the effects loop. Just set your send there to 100 or so and that track will be sent to the internal effect loop and be affected by whatever single effects you have turned on. To print these tracks with effects you can either premaster or create a bounce mix. Just make sure you mute any tracks you don't want in a bounce because a bounce will record anything which is on the stereo bus.
(See page 42 in your manual for Tascam's explanation for using the single effect and page 58 for how to create a bounce submix).
Hope this helps.
bd.
Jan 26, 2009 | Tascam 2488 Portastudio Multitrack...
The pictures on my sansa mp3 8gb
I didn't realize the sansa clip supported pictures - are sure you posted in the right section?
Just giving you a hard time. If you have a Sansa Fuze 8GB:
Looping a Slideshow
1. Press Submenu button while viewing photos.
2. Scroll to Loop and select it.
3. Use the thumbwheel to select Loop on or off.
4. Press the Select button.
5. Press the |<< button to return to previous menu.
Specifying the Slide Duration
1. Press Submenu button while view photos.
2. Scroll to Slide Time and select it.
3. Use the thumbwheel to highlight and select the desired duration (from 2
seconds to 30 seconds).
4. Press the Center button.
5. Press the |<< button to return to the previous menu.
Selecting Slideshow Music
2. Use the thumbwheel to highlight Slideshow Music and select it.
3. Select Current Song (if a song is currently playing) or Music Go List
(plays music from the Go List) then press the Center button.
4. Press the |<< button to return to previous menu.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Problem with MP3 player-Stops after one song
On closer look (after my long road trip to test this out), I realize when you hit Browse, there's a button on the bottom titled Play All. If you select this button, the buttons mentioned above work as intended, and the Forward, Backward buttons bring you to the next or previous songs in the list.
Sep 27, 2008 | Garmin Nuvi 660 GPS Receiver
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
66 people viewed this question
 Grubhead
Grubhead
