Question about Creek 5350SE Amplifier
Losing sound, hearing scratchy noise from the speakers
Right after turning on the switch, I hear scratchy noise from the speakers intermittently. Losing sound output, reduce in output level occurs also. This happens on both channel, but left side seems to be worse. I have had a retailer look at twice with no success. They could not find anything wring. I sent the unit to a retailer in L.A. who was recommended by MusicHall. They also could not recreate the problem. When I touched the metal case, it sometimes fix it. So, I guess there may be a solder crack somewhere. Has anyone had a similar problem and found a solution ? Thanks,
  • cdvibes Aug 18, 2008
    i have behringer EP1500 when i switch on the amp only and leave for about 3 minutes i hear a scratching sound coming from the left channel whats wrong.
I think I had the same problem with the DSP-A1000. The problem is probably dust in the CD/Tuner/etc switch. After checking all the connectors and wires in the machine and cleaning and contact spraying them, the problem still persisted. I found however thad by putting pressure at the printplate above the CD/Tuner/etc switch,I could reproduce the problem(make the noice louder/less loud). I took the switch out and cleansed it inside and outside with contact spray. turned the switch a couple of times, let it dry, et voila, problem solved! good luck! gr, Bram
Posted on Dec 15, 2006
    Scholar:
  • 68 Answers
This description was copied from a description of the Creek 5350SE. `The circuit consists of a passive input stage and volume control which then feed the power amplifier section. It is possible to make this pre-amp section an active device by adding a gain module'. This sounds like an old problem with volume controls which are essentially, a potentiometer. If there is absolutely no voltage on the slider of the potentiometer then no noise is generated, and amplified. In your case a voltage is generated when you power up from your input devices, such as a record player or cd player or mixer unit. The retailer in LA could not recreate the problem as he may not have had the same audio set-up. Try to isolate the input by not connecting the other units, and switch on to test. If you find the culprit unit you will find it has a DC voltage on its output on switch on, which dies away slowly. Touching the metal case is a way of discharging this voltage build up, and you should also make sure the units metalwork are connected, with extra wires. If you can make the pre-amp section an active device by adding the gain module this will most likely cure the noise problem. If the output speakers protection relay circuit, inhibit time can be increased by adjustment this would mask the effect, which is what its for.
Posted on Oct 20, 2006
My yamaha tuner does this every few months. POwering down the receiver and rapidly turning it to full volume then no volume a dozen times clears the contacts on the volume potentiometer. The problem always goes away for another couple of months.
Posted on Apr 27, 2007
  • 1,883 Answers
Contact spray to use in long ridge switches for input selection
potentiometers , look the solderings especially on active components with heatsink , if you have an older amplifier its good to further draw after a bit the screws on the mounting of the output transistors coldspray if somewhere are 1n4001 diodes are used replace them with the 1n4004 or 1n4007
Posted on Nov 21, 2016
    Novelist:
    Champion:
  • 236 Answers
Can you confirm for me what is your amp? is it Yamaha? what model please
Posted on Mar 19, 2008
I encountered exactly the same problem on my setup: Alesis Masterlink ML9600 directly hooked to a Yamaha P5000S. I can hear little sparkling sounds and the output volume is very loud. When connecting my mixer (Mackie 1642 VLZ-III) or my digital mutlitrack recorder (Yamaha AW1600), this problem is absent. Actually, when thinking about it, I believe that it's obvious that a preamp should be place in-between the CD player and the power amp. I consider adding a very simple preamp, like a Rotel RC-06. Effe
Posted on Oct 08, 2007
It seem to be the cold solder on the Gain Stage circuit. It build up a lot of heat when the unit is on. The Gain Stage is below the input relays. Both channel need to re-touch all the solder points.
Posted on Aug 24, 2007
Check the outputs with a multimeter and look for voltage leaks
Posted on Jun 01, 2007
I had the same problem you need to get the selcter switch replaced as they had problems with some of the batch of swicthes once you get a replacement fron yamaha you will have no problems
Posted on Feb 24, 2007
Azuma I hope that you are still checking back to this post. I have the same piece of equipment with the same problem. I suspect that both of us have leaky capacitors. I have heard more than once that Krell has this problem. Some capacitors are "self-healing" when the dielectric starts to break down, which explains the intermitant part, but once they start, they only get worse. Check out the web site stereorepair.net. Larry
Posted on Jan 25, 2007
    President:
  • 3,130 Answers
Im surprised the techs did not find it, as it sounds like poor connections in the speaker safety relay. It really shound be replaced. Good Luck PS please dont forget to rate this thread.
Posted on Oct 19, 2006
4 Suggested Answers
  • 104 Answers
SOURCE: scratchy noise on my record player
Sounds like its time to change the needle [Stylus ] , there are a few types But the two most common are Saphire and Diamond Stylus pay the extra and get a diamond if you can , Hope this helps
Posted on Jun 01, 2009
SOURCE: Creek 5350SE amplifer left Channel dead
It's the ribbon cable that is likely at fault. There are actually three computer type ribbon cables in the amp. I believe the cable that is responsible for the drop-out of a channel is the widest (longest) of the three, but you really need a tech to look at it and replace the cable. But please note that the new cable may also have defects in manufacture and that it may take some time to order a new cable from Creek. I had a tech solve the problem permanently by removing all three ribbon cables and then hard-wiring the connections together - that is to say, point-to-point wiring. My cost was about $250, but as you can imagine, there is extensive labor involved. Good luck!
Posted on Aug 13, 2009
Grubhead
  • 5342 Answers
SOURCE: Creek SE 5350 one channel without sound
I think you will find that the fault is either a dry joint somewhere (have you moved it recently?) OR more likely a transistor. It might be caused by one getting very hot! Thus shutting down and coming back on when cool.
The best way to track this troublemaker down is to spary each transistor (in the left channel only don't bother with the other or Power section) with Servisol Freezer spray. Wait for the thing to play up then spray -one at a time- if it pops on you have got the bugger! To make certain apply a soldering to it and it should act up again. Spray again to confirm.
Posted on Apr 12, 2010
Sherwood RVD 6095rds Hi. After a short while of about 20 minutes. My speakers cuttout like they are losing connection. Next I hear some loud pops from the speakers. And it resets itself to standby.
Sounds like DC leakage....pre-drive and/or output transistors (or IC) becoming intermittent often pass DC voltages to the speakers. The "pops" you hear are these DC pulses being passed to the speakers and the "cutout" is the protection circuitry doing its job...protecting the speakers. Speakers want AC voltages...plus voltages moving the cone in one direction, and a negative voltage moving it in the opposite direction. DC voltages push the speaker cones in a single direction and hold it there until it fails. The bad news...it's repair shop time.
Mar 29, 2015 | Sherwood Audio Players & Recorders
I love my speakers, but when iTunes stops playing music, they make a horrible scratchy crackling noise....any suggestions?
is your itune also connected for charging when you connected to your speaker? it could be the possible causes during itune finish playing the internal charging noise from switching supply adaptor come into the audio line get into your speaker, so you may hear the noise. If this is the problem, you may try to use differentiate line in isolator. mostly people use in the car to isolate engine alternator noise. you can find in car accessories shop.
Jul 20, 2011 | Acoustic Research AW825 Main / Wireless...
My sub make a strange noise. It doesen't work anymore.Tks.
Strange noises can come from your amplifier or the sub itself. The most likely cause of the strange noise is the speaker just before it dies! If you have been using the sub-woofer at high volume levels then you probably have damaged it. Try testing the sub-woofer using a multimeter(on ohms setting) it should give you a reading from 8 to 4 ohms. Sometimes they may give readings as low as 1 ohm. When testing the speaker/sub you should hear a soft scratchy, thumping or clicking sound. This indicates that the speaker may still be working. If you don't have a multimeter try a 1.5 volt battery (say a AA), DONT USE HIGHER VOLTAGE BATTERIES they may damage the speaker! You will hear a clicking, scratching etc sound from the speaker which may indicate that it is still OK. If the speaker seems OK the problem may be in the amplifier, which I suggest you bring to a professional repairer. When buying speakers and amplifiers make sure the power handling of the speaker is equal to or greater than the amplifier output power. This should stop speakers from getting damaged. Make sure the speaker and amplifier specifications are rated in the same manner ie RMS PMPO Peak. A 100 Watt PMPO speaker will not survive the output of a 100Watt RMS amplifier!
Feb 08, 2011 | Audio Players & Recorders
Lights are on in the small speakers but no sound is produced...there is a short scratchy sound when I juggle the speker wire from sub woofer. I hooked speakers up to a different MAC and now am trying to...
Hi there , the green light just means its getting Power, it doesnt mean that its going to give sound, It could be that you dont have Drivers installed for your Sound card which is causing it too not get sound , but when it makes that static noise , its the Wire just causing Static with the Sub , just means its getting power , The + and - sign is the volume control ...Try see if you can turn it louder with the + . maybe it is low enough not too hear.....Hope this helped Bud
Happy new year.
Jan 03, 2010 | JBL CREATURE II Computer Speakers
The speakers are making a very scratchy noise. They are hooked up to my desktop computer. When first purchased last year, they sounded quite good. Now, they are very scratchy and not on high volume.
Do you by any chance have any other wireless device like a cell phone near the speakers when you hear this?
Any kind of device that has a magnet field will cause scratching sounds on the speakers. I discovered this quite by accident with my old Boost mobile phone.
Debbie Mahler
MICE Training, Technology & Education
mice.org
Oct 24, 2009 | Bose Companion 2 Series II Multimedia...
Blown?
Typically you will hear a popping sound when the bass hits, or you may not have any sound at all.......If the sub sounds good then your ok.
On a side note, pulling on the cone while the sub is in operation can damage the unit because it cannot move freely under load
Sep 25, 2009 | Clarion SRR6923 Car Speaker
RADIO SHACK TRC-447
A number of things....faulty speaker (you can scratch test this with a torch 1.5 volt cell....cell pos goes to 1 speaker terminal
and cel neg goes to other speaker terminal..you can conect it any way around with flying leads from the cell...just keep touching the terminal with one flying lead...you will hear a scratching sound in the speaker) have your mike checked...test the tx/rx relay on the circuit board for tx/rx switching, or, a failed
driver transister in the output stage....the list is many
Cheers flyingfox@people.net.au
Jun 21, 2008 | Radio Shack TRC-447 CB Radio
One speaker not working and Scratchy Audio
just check is there any loose contact frm that speaker connection plug out the cable connect it again and have a check it may work...
or may be any time the speaker may be falled on ground so may be there is problem
Nov 23, 2007 | Gateway GMAX 5100 Computer Speakers
Scratchy noise?
Are the speakers old? The only thing that can make a random scratchy noise on the speakers as far as I know is a dirty volume knob. Try turning it all the way up and all the way down (with nothing playing) and see if that helps. If it does, blow them out with some compressed air. I'm thinking your issue is probably software / driver related though, does the scratchiness happen in other programs? WinAmp? Windows Media Player? .. if it does, you've narrowed it down to a driver-related issue, go to your sound hardware's manufacturer website and download the latest drivers.
Jun 15, 2007 | Altec Lansing 641 Computer Speakers
5,648 people viewed this question
Top Creek Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Creek Audio Player and Recorder Expert? Answer questions, earn points and help others
