Question about Minolta DiALTA Di520 Laser Printer
Minolta di520 we have a network printer with an error on it C-OF34, is there a way to reset this, it started after a paper jam from the top feeder. Thanks
  • Minolta Master
  • 1,297 Answers
COF 34 is a code to refer T/C recovery failure as detected by ATDC sensor.Change ATDC sensor,if problem persist,change developer(starter) and then run F8 and F5 function operation in that order.Developer change every 1000000 copies.
Posted on Jul 30, 2009
C-0400 Minolta DiALTA Di520 Laser Printer
Exposure lamp failure (Burned out or the control board that controls it. The EXPOSURE lamp is the very bright light that comes on below the big glass on top. Reset the code open the front door to your left is small access remove it press the trouble reset button if the code comes back get a new lamp try the web site below for a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Oct 06, 2011 | Minolta DiALTA Di520 Laser Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
At power on, my bizhub 222 immediately gives me a paper jam error in the top feeder every time the machine is turned on.
If you have verified that there is no jammed paper, then I would suggest taking a can of compressed air and blowing the doc feeder out as best you can. Often times dust or paper scraps and debris can become lodged in the paper path, frequently blocking a sensor, thus creating a jam (despite the lack of paper.) As well, you might try running a thick piece of card stock through the feeder, as this will act to dislodge any stuck paper bits.
Let me know how it turns out.
David R.
Dec 09, 2010 | Konica Minolta Bizhub 222 Black and White...
I have a Minolta Dialta Di520 that shows an error code of c-0110. The machine was working fine before being moved. It may have been bumped along the way. Also, the FN3 finishing unit is not connected at...
Image Transfer/Paper Separator Wire Cleaning Motor M8's failure
to turn · Faulty Transfer/Separator Wire Cleaning Home Position Sensor PC17
would be in the middle section, under the drum assy that has to very fine wires a device that looks like it would clean them, will the cleaning device is jammed or the motor that run it is jammed burned out, or the control board is bad.
Aug 01, 2010 | Minolta DiALTA Di520 Laser Printer
Minolta DiAlta model 151f, when i try to use the automatic paper feed on the top of the machine the paper goes in about half way then stops then a message comes caution original doc jam
Try cleaning the pickup wheels that pull the paper into the feeder. There might be an electrical sensor problem also that is not sensing the right paper size. So lets start with cleaning the feeder
Jan 04, 2010 | Minolta Office Equipment & Supplies
When trying to fax I get an error "open adf cover"...
You should be able to. It sounds like you've got a paper jam in the document feeder. Chances are there was a jam and part of the document (a small peice perhaps) is still lodged in the document feeder unit.
Aug 31, 2009 | Konica Minolta PagePro 1390MF All-In-One...
Konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Doc. feeder jam, after paper removed completely
HP LaserJet 3030 All-In-One Printer
Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
Code 1039 + C0F33 with paper jam
COF 33 ATDC sensor problem
1039 -communication error for remedial this code turn OFF and ON the power.
Aug 01, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta Di520 false misfeed
Try resetting the copier, with the copier powered on open the front door remove small cover on right hand side press reset button close front door, the machine should boot
Feb 06, 2008 | Minolta DiALTA Di520 Laser Printer
222 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
