Question about Mirage FRX S10 Speaker
Frx s10 subwoofer huge problem
I have an mirage frx s10 subwoofer and a sony dg600 reciever i dont know how to hook it up could someone PLLLLEEEASSSE help me it has a weird type of outputs on the back of the sub i dont know were to hook them up on my reciever
3 Suggested Answers
DaveMc3
  • 57 Answers
SOURCE: Internal damage to Mirage BPSS-210 Subwoofer amp
Something getting hot probably means something shorted out. You probably know that since you replaced the fuses already... . Can you give me some idea of what you do and do not know about electronics? Then I will say fewer dumb things. . When troubleshooting any electronic device, especially amps, open it up and look at the circuit board. Look for burned board and components. Then test to see if the burned/blown component had reason to blow (it probably did). . Often a shorted transistor runs too much current through some other component and the other component blows up. . Another cause, less common, is a shorted cap. . Look at the schematics if you have them, if not, you may have to create one to make sense of it. . Or take it to a shop where somebody does this all the time. The only one here went belly up in the last 12 months... . . About the pots . Try blowing out the pots which are popping with some tuner cleaner. Use with caution, and always with everything turned off and power cords unplugged. . Pots do not usually make popping noises unless they are very old or live in a very dusty place... . I found the manual, but no schematics... http://docs.google.com/viewer?a=v&q=cache:9Doi39-AcW0J:www.miragespeakers.com/images/download/374.aspx+Mirage+BPSS-210+schematic&hl=en&gl=us&pid=bl&srcid=ADGEESjBKgLSTb8wp5SRWIOWd-gE0INdBXbfz5QDNJ_3esye4_R2Q9aKba8cEePSWQWOebeXB9zXnJSelIel2bLSR5q6KExe8MVjOk1zqFKk4K-ruti_797yf1Ig3CIcUNjE49jx8DAr&sig=AHIEtbS6udedt_o6GqL7ALPunU0v3vMvuw . You might be able to get better, more exacting help on the Mirage Forum... http://community.miragespeakers.com/forums/ But maybe not, since the Subwoofer section gets less than one post per month, and the much busier Technical Questions section only has 23 in the last 12 months.
Posted on Feb 08, 2010
dunnbiker
  • 8546 Answers
SOURCE: My Mirage S10 subwoofer
More diagnosis first. We can't assume the source is squawking bass to this thing and you don't mention that you know that to be the case. IS it? The problem could be up the food chain.
We also don't know if you're feeding it Speaker Level or Line Level.
Prove the subwoofer amp is dead or alive by jacking in any source you have that has an RCA output (Tape Out on your unnamed source, CD, TV, etc). Turn the sub volume down to minimum to start as most RCA outputs are at maximum volume. Try that to assess the amp's health. Still dead? Get it worked on.
Posted on Jul 07, 2011
Parts
It is probably easier to make one.
May 01, 2013 | Mirage FRX 7 Speaker
OmniS10 does not work
Mine has issue with the sub input that runs from the receiver sub output. So I don't have the LFE effect. I have to use the secondary hookup which is:
-run your front speaker wires from the receiver into the input. Then run wires out back to your front speakers.
Is your completely dead period? Or is the light coming on? If its dead, it may be a fuse or the power supply has failed....if the light comes on. Try the secondary hookup. Make sure both your reciever and the sub are unplugged. Plug them back in after you have hooked everything up..
Feb 08, 2013 | Mirage OMNI S10 Speaker
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
My Mirage S10 subwoofer light comes on showing the subwoofer is on but I cannot get any bass sound to come on. How can this be resolved?
Jul 07, 2011 | Mirage Prestige S10 Subwoofer Speaker
Lost my remote how to adjust my bass and treble levels from the front of the reciever
Hello,i hate to be the bearer of bad news but to change almost everything on that model you need the remote,including channel levels ,bass and treble etc...
Feb 11, 2011 | Sony STR-DG600 Receiver
Cant operate awa ht228 without remote control, which is not working, would another awa remote work, cheers dave.
I would imagine a similar remote from the same maker would share some common functions and 'language' unless AWA is NOT the Original Equipment Manuafacturer of both products.
Try these guys for a direct replacement:
$90.42
http://www.diyparts.com.au/index.php?cPath=103_81979_81985&osCsid=1a77635669ec1ef21177dc5ccc7b40e2
Or eBay. Search the model number and 'remote'.
Jan 19, 2011 | Mirage FRX One Speaker
Can i hook up my SA-WM20 subwoofer to my sony DAV-S500 home theater
As long as your sony reciever has a sub out connection you should be able too. This powered sub you have has a rca sub input which should coincide with the receivers rca sub out.
Aug 04, 2009 | Sony SA-WM20 Subwoofer
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Hook-up
You should first check the ratings and specification. Then only you can hook up. But from my side plz always use compitable systems
Dec 08, 2007 | Sony SA-WM20 Subwoofer
HOW TO HOOK UP SUBWOOFER
sell your bose system and buy a real home theater surround sound system with a real subwoofer and not a Bose "Bass Module"! Problem Solved!
Dec 07, 2007 | Audio Players & Recorders
57 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
DaveMc3
DaveMc3
berggei
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
