Question about Hitachi 55HDM71 55 in. HD-Ready Plasma Television
Hitachi p55h4011 my tv has no power the fan doesn't even come on
  • 29 Answers
HI.
FIRST CHECK THE MASTER POWER SWITCH.
Posted on Jan 02, 2009
    Sergeant:
    Champion:
  • 227 Answers
If the tv is completely dead, your first step is to check the fuses in the power supply.but if you get the standby light, and nothing happens when you hit the power button, you need to call the repairman
good luck
caypianan@yahoo.com
Posted on Nov 08, 2008
Hitachi P55H4011 No Picture & No Sound
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Dec 21, 2014 | Hitachi Televison & Video
Hitachi modle # p55h4011 blue light blinking 4 times
This is an error code signalling that there are defects inside the TV, and might need service.
Aug 23, 2012 | Hitachi Televison & Video
Hitachi p50h401 the power light keeps flashing
If you have a flashing red light, try this first: The flashing red light is, according to the Hitachi service manual, an indication of exactly one problem. It is that the fan (internal, blows air over the power supply heat sinks) has failed. In my case, it failed by continuing to spin (very confusing), but put out a signal (3V on the white wire of the fan harness) that it has failed (I had to look up the data sheet on the fan to figure this out). A new fan from Arrow $10 fixed the problem. If you suspect your fan, spinning or not, you can safely short the white to the black wire to see if your TV remains on after being turned on (solid red light), and then try turning your TV on (blue light) to see if it works.
Oct 17, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi L26D103. Less than 2 years old. Working fine one day. Turned on the next day and the sound works, but not the picture. This is an issue when in both the TV and DVD modes.
Good day!
If your TV doesn't have a picture even you play a DVD it means there is problem to your TV.It could be the Inverter board or the cold cathode lights is busted.
This are the steps on how to fix that problem.
  1. Remove the back cover of your TV.
  2. After that,plug in the TV and power it ON to perform a voltage data.
  3. Check the the output voltage of your power supply by using multimeter tester (range in DC) then check the 24vdc(supply of inverter board).
  4. If you have 24vdc in power supply output,check also the input voltage of inverter board if have 24vdc.If doesn't check the wire connection from power supply to the inverter board.
  5. If have you input voltage of inverter then check the high voltage output of it,if have at least 500vdc so be careful to check it because it have a high voltage.
  6. If doesn't have high voltage output replace the inverter board and if have a output voltage the cold cathode lamp inside is busted so you have to replace it
The inverter board looks like this:
You can buy it to this link: http://www.shopjimmy.com/catalogsearch/result/?q=Hitachi+L26D103+inverter+board
If this solution will be helpful please rate my answer. Thank you and good luck.
May 06, 2011 | Hitachi L26D103 LCD TV
My Hitachi 50V500A tv just quit working while I was watching it.
Symptom: Dead, F901 is open.
Cause: Shorted D902 on the power supply board.
The full service manual for this model, (Hitcahi 50v500) can be downloaded at http://fletchermanuals.com for only $10.00.
Jan 07, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My 42HDS69 Hitachi has a recurring problem of not turning on. I unplug from outlet for awhile and sometimes it will turn after I plug in outlet, Other times it takes a few hours for TV to turn back on. ...
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Dec 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
T.V. Loses its picture when it gets hot but I can still hear it
Hitachi sets are prone to Power Supply Faults.
I think your PSU is getting too hot, then shutting down.
The better sets have Fans in them.
Either repalce the Power Suplly or put up with the fan.
It will however still fail in the end, one or more components are allready failing under stress / load.
Thanks
Sep 06, 2009 | Hitachi 50HDT50 50 in. Plasma Television
Cooling fan won't turn off.
this set has more then one fan; one fan will run all the time to cool the digital circuit board---if it is the actual LAMP fan then you have a problem---the digital fan is very small and not located near the lamp.
Aug 06, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v 500a
This fan is to cool down power supply temperature and even in standby mode power supply works.
Nov 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 55HDM71 55 in. HD-Ready Plasma Television Logo
322 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
